Administrators MaLd0n Posted April 28, 2020 Author Administrators Posted April 28, 2020 5 hours ago, kahiser said: Hi MaLd0n the config looks good what ur gpu? if u use a 5700 line, need catalina 10.15.1+ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mjmtvman Posted May 21, 2020 Posted May 21, 2020 hi Maldon i try your guide from windows installation again and i am stuck now on the screen below i don't have any other hackintos to make any settings on clover. https://drive.google.com/open?id=1TSRFRQ3BKyjzHTySFePFe8-MMCpcAbcL to inform you my system is x299 with 10980xe thanks
Administrators MaLd0n Posted May 21, 2020 Author Administrators Posted May 21, 2020 23 minutes ago, mjmtvman said: to inform you my system is x299 with 10980xe i made one yesterday for one client, in this case i need patch dsdt for install too machdep.cpu.brand_string: Intel(R) Core(TM) i9-10980XE CPU @ 3.00GHz -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mjmtvman Posted May 21, 2020 Posted May 21, 2020 1 minute ago, MaLd0n said: i made one yesterday for one client, in this case i need patch dsdt for install too machdep.cpu.brand_string: Intel(R) Core(TM) i9-10980XE CPU @ 3.00GHz but there is any way to install mojave olarilia image? then i can provide you the files
Administrators MaLd0n Posted May 21, 2020 Author Administrators Posted May 21, 2020 1 hour ago, mjmtvman said: but there is any way to install mojave olarilia image? i edit files before and put full efi folder into Olarila image and install is done, many details -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mjmtvman Posted May 22, 2020 Posted May 22, 2020 (edited) Maldon i use my 9820 cpu to install mojave please make your magic MaLd0n can you prepare the file for me? Send me fords-iMac-Pro.zip Edited May 23, 2020 by mjmtvman
Administrators MaLd0n Posted June 12, 2020 Author Administrators Posted June 12, 2020 On 5/22/2020 at 8:04 AM, mjmtvman said: Maldon i use my 9820 cpu to install mojave DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
AleX299i77740x Posted June 14, 2020 Posted June 14, 2020 (edited) Hi, following the guide and after many attempts, I successfully installed Catalina (10.15.5) on Aorus x299 gaming 7 / i7 7740x /xfx radeon rx 570 / samsung ssd 860 evo, but the system seems unstable ... what is the best way to find errors? From the terminal with grep TSC I get the errors "unsynchronized TSC for cpu 2 and 4". I send my EFI hoping that you can help me. Thanks Edited June 24, 2020 by AleX299i77740x
Administrators MaLd0n Posted June 14, 2020 Author Administrators Posted June 14, 2020 52 minutes ago, AleX299i77740x said: Hi post one full dump Extract tables with F4 key in Clover boot screen, boot into system and run this apphttps://www.olarila.com/files/Utils/RunMe.app.ziphttps://www.youtube.com/watch?v=k9wmIfGLe3A -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
admkazuya Posted August 1, 2020 Posted August 1, 2020 Hi, @MaLd0n I'm using ASUS X299 Tuff Mark2 on Catalina, but when I update BIOS(2004), Catalina dose not boot. Any help ?
Administrators MaLd0n Posted August 2, 2020 Author Administrators Posted August 2, 2020 17 hours ago, admkazuya said: I'm using ASUS X299 Tuff Mark2 on Catalina, but when I update BIOS(2004), Catalina dose not boot. sound like a bios option msr option is disable? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
admkazuya Posted August 7, 2020 Posted August 7, 2020 On 8/2/2020 at 11:58 PM, MaLd0n said: sound like a bios option msr option is disable? I already disabled msr option. Attach my EFI Directory, please check this one.
kmakino Posted September 5, 2020 Posted September 5, 2020 On 8/2/2020 at 11:58 PM, MaLd0n said: sound like a bios option msr option is disable? Yep, already disabled. So another problem happend. Intel USB has gone.... Plase help me SendMe file was 5.2mbEFI.zip
Administrators MaLd0n Posted September 5, 2020 Author Administrators Posted September 5, 2020 1 hour ago, kmakino said: SendMe file was 5.2mb upload in google drive -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
GOVERNOR Posted November 13, 2020 Posted November 13, 2020 I can't boot the macOS Big Sur from usb, its show error logs.
Administrators MaLd0n Posted November 14, 2020 Author Administrators Posted November 14, 2020 7 hours ago, GOVERNOR said: I can't boot the macOS Big Sur from usb, its show error logs. what error? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
GOVERNOR Posted November 14, 2020 Posted November 14, 2020 Hi, this is the error I encounter using olarila bootable. https://drive.google.com/file/d/1WwPb_efXWuKDBeGNQ8IE3Yoqi4f2C1JD/view?usp=drivesdk from the macos catalina everything work fine unlike this macos big sur. Can you help me how to solve this?
Administrators MaLd0n Posted November 15, 2020 Author Administrators Posted November 15, 2020 10 hours ago, GOVERNOR said: how to solve this? https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
GOVERNOR Posted November 15, 2020 Posted November 15, 2020 Thanks but its show not supported https://drive.google.com/file/d/1e95x4h2JiXLDE-s6PH3u8uqH9loyV14s/view?usp=drivesdk
Administrators MaLd0n Posted November 15, 2020 Author Administrators Posted November 15, 2020 28 minutes ago, GOVERNOR said: Thanks but its show not supported u need use a supported smbios 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
