Hackintosh Guide - High Sierra / Mojave / Catalina / BigSur / Monterey on X299 with Clover Bootloader
1 hour ago, mjmtvman said:
i  followe the guide and I take panic error below when i try to install majove iso
try APIC patch, acpi tab
3 minutes ago, mjmtvman said:
which tables you want to drop?
4 minutes ago, mjmtvman said:
i don't have macos to modify clover.
EFI.zip
update bootloader
Hi MaLd0n,
You can help to me, with this difficult machine... I've managed to advance to this point with the image of Catalina, with this error:
Kernel panic
I have tried several different settings but without success:
- Value setting=15 in cpus for my i7-9800X processor in both VoodooTSCSync.kext, and TSCAdjustReset.kext.
- Pach APIC activation.
- SMBIOS change iMacPro1,1
Specifications:
Dell Precision 5820 Tower X, i7-9800X 8 Core 3,8Ghz, (Intel Core X series CPUs with Intel X299 chipset.)
For mounting tests: R9 280X, SSD SATA 512gb and 8gb Ram 2666mhz.
Attached CLOVER folder, DSDT and motherboard layout
EFI-CL-CAT-DELL-5820-X299.zip
DSDT-DELL-5820-X299.aml.zip System board components Dell 5820X_en-us.pdf.zip
Edited by kahiser
On 4/17/2020 at 8:58 PM, MaLd0n said:
Hi MaLd0n,
Thank you very much for the new EFI!
SOLVED THE PANIC KERNEL...!
What was the problem?
This has totally solve the boot up for the USB installer.
I had to try several installs, as the installer froze at the end of the process, but oddly enough when rebooting manually at the last install, I found that it seems to have installed correctly Catalina.
I see some small problems, but it's already a matter of fine-tuning DSDT.
- Does not correctly detect the GPU.
- Audio I/O
- Wifi and bluetooth
- Sometimes the screen freezes and you have to turn off the machine.
- Does not complete the restart process.
I'll also activate the Thuntherbolt ports to check their operability
Greetings
K.
Edited by kahiser
u need extract one full dump with my efi
On 4/21/2020 at 10:18 AM, kahiser said:
Hi MaLd0n
I'm enclosing the folder like you asked.
I tried to follow some forum guidelines, but I was only able to solve a few small things.
Thank you again for your help...!
Send me Mac-Pro-Dell
Gracias
K
HI MaLd0n,
Yesterday I was working on a DDST for the Sapphire Pulse Radeon RX550 in Mojave, for DELL 5820 X299, it seems to work correctly, but I don't know if it is completely correct.
I'm learning as I go, watching various tutorials.
Photo Mojave RX 550
I am enclosing a copy for you, or for other colleagues in the community
SSDT-DELL-5820-X299-RX550.zip
for rx550 u just need it inside video device
Quote
into device label PEGP parent_label PEG0 insert
begin
Name (_SUN, One)  // _SUN: Slot User Number\n
Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method\n
                    {\n
                        If (!Arg2)\n
                        {\n
                            Return (Buffer ()\n
                            {\n
                                 0x03\n
                            })\n
                        }\n
                        Return (Package ()\n
                        {\n
                            "device-id",\n
                            Buffer ()\n
                            {\n
                                 0xFF, 0x67, 0x00, 0x00\n
                            }\n
                        })\n
                    }\n
end
This method was simpler than the DDTS I did... jejeje
Did you have time to review the package generated by the RUNME?
K
Edited by kahiser
