Hackintosh Guide - High Sierra / Mojave / Catalina / BigSur / Monterey on X299 with Clover Bootloader
On 5/22/2020 at 8:04 AM, mjmtvman said:
Maldon i use my 9820 cpu to install mojave
Hi, following the guide and after many attempts, I successfully installed Catalina (10.15.5) on Aorus x299 gaming 7 / i7 7740x /xfx radeon rx 570 / samsung ssd 860 evo, but the system seems unstable ... what is the best way to find errors? From the terminal with grep TSC I get the errors "unsynchronized TSC for cpu 2 and 4". I send my EFI hoping that you can help me.
Edited by AleX299i77740x
52 minutes ago, AleX299i77740x said:
Hi
post one full dump
Extract tables with F4 key in Clover boot screen, boot into system and run this app
17 hours ago, admkazuya said:
I'm using ASUS X299 Tuff Mark2 on Catalina, but when I update BIOS(2004), Catalina dose not boot.
sound like a bios option
msr option is disable?
I already disabled msr option.
Attach my EFI Directory, please check this one.
Yep, already disabled.
So another problem happend.
Intel USB has gone....
Plase help me
SendMe file was 5.2mbEFI.zip
upload in google drive
7 hours ago, GOVERNOR said:
I can't boot the macOS Big Sur from usb, its show error logs.
what error?
28 minutes ago, GOVERNOR said:
Thanks but its show not supported
u need use a supported smbios
  • Thanks 1
I install already. But i have a problem.
when intry to unmount my hdd to check / edit the config. I can’t see any clover inside on efi main hdd.
edit:
i cant boot normal, always ready to boot on preboot. How to fix this sir?
Edited by GOVERNOR
2 hours ago, GOVERNOR said:
but, when i try to run the preboot. Its work, any idea how to fix?
use preboot
  • Thanks 1
8 hours ago, MaLd0n said:
use preboot
Thank sir! It is impossible to rename the Boot from Preboot to MacOs? I try to edit via clover entries but wont work.
no. use preboot
