[Quest] What's method correctly to patch wireless and audio?
Hello everyone, i need advice to make my hackintosher work funtionaly, with this specs:
    Mother board: 0RN98T
   CPU: i3-5005U
   GPU: HD5500
   Wireless and Bluetooth: AR9002WB-1NG (I replaced the in-built one)
   Audio Card: ALC256 (branded as ALC3234)
   Ethernet: RTL8111
Now i make my laptop can dualboot high sierra 10.13.4 with windows 10, ethernet and wifi, bluetooth work, applehda work too. But i have a question:
At the moment, what's methol right to patch my wireless and AppleHDA correctly? Seem from before install hackintosh in ASUS K53, i haven't update other method patch, cause with new Dell hackintosh, i dont know about toledaARPT.kext
Audio, u can test with 3 layout ids
What correct wifi model? Have support?
Thanks, i check code sound with AIDA64 it show me ALC255 :(. I will try it, but my question is newest method to patch AppleHDA and Wireless, bro? cause i haven't hear about toledaARPT kext before, i search but got nothing information about it
Thanks, i check code sound with AIDA64 it show me ALC255 . I will try it, but my question is newest method to patch AppleHDA and Wireless, bro? cause i haven't hear about toledaARPT kext before, i search but got nothing information about it
Arquivo Comprimido.zip
(175.82 KiB) Downloaded 1 time
a little information with it, sir? sr I'm amateur :(
remove toledaARPT and put two kexts
Thanks, its work for me! So toledaARPT is obsolete right, sir?
idk, i don't use it
hi @MaLd0n, it's me again, sir!
AR9002WB-1NG wifi combo card [AR9285 + AR3011 (bluetooth)]
In my case, wifi is working stable, but bluetooth almost failed, sometime working, and this is error, how can i solve it, make bluetooth working normaly? thanks
issue bluetooth.zip
thanks so much, sir!
but how to build kext from here for my specs?
seem to old, i mean how to build from github, sir?
chuctran@Trans-MacBook-Pro ~ % git clone https://github.com/headkaze/OS-X-Atheros-3k-Firmware.git
Cloning into 'OS-X-Atheros-3k-Firmware'...
remote: Enumerating objects: 280, done.
remote: Total 280 (delta 0), reused 0 (delta 0), pack-reused 280
Receiving objects: 100% (280/280), 320.66 KiB | 416.00 KiB/s, done.
Resolving deltas: 100% (133/133), done.
chuctran@Trans-MacBook-Pro ~ % makefile
zsh: command not found: makefile
