Need help installing High Sierra on GA-P75-D3, i5-3570
Hello everyone.
I need to install Hackintosh on my PC. I have worked on MacOS before but never tried to install Hackintosh one so I'm pretty much newbie here. Can I install Hackintosh on this PC?
Motherboard: GA-P75-D3
CPU: Intel i5-3570
RAM: Kingston 2x4gb
GPU: Asus GTX 650
Specs are similar to this iMac: https://everymac.com/systems/apple/imac/specs/imac-core-i5-2.9-21-inch-aluminum-late-2012-specs.html
If I can install Hackintosh on this PC, Where can I start?
Thanks & Regards.
Images
viewforum.php?f=51
Tutorial
viewtopic.php?f=50&t=6255
Thank you. I'm going to download "High Sierra Olarila 10.13.2 HFS / APFS Final" and try to install it. I will be updating my process here.
if u use apfs, use 10.13.4 image
