Hi Sir, after i installed VoodooHda audio is not working ,and graphic showing wrong, It should be hd 630
This is my SEND_ME
http://www.mediafire.com/file/6kjkp0hyh ... ok-Pro.zip
Thank you
ur install, files is very dirt, very strange
is hard to put good files and changes
Please Help.
Thank you very much.
CLOVER.zip
Stuck here
http://picture.in.th/id/8a9c67e1617b0af ... f9b9926a7f
first, press barspace and block lilu.kext and Intelfix kext
if dont work u can drop a edited dsdt
press O key in Clover boot screen, go to Acpi Patching/DSDT Name and put DSDT02.aml and remove file in clover/acpi/patched
Now I can boot in to Osx with HDD.
Sorry for my English :(
SPEC
Lenovo y520
PROBLEM
- intel graphic hd 630 7mb
- intel wireless can't use
UPDATE FIRST POST
-Clover folder
-Patches
-Mojave
-Cosmetics
try update Clover bootloader
--Audio--
-AppleALC
HDAS to HDEF patch and correct layout-id for your audio codec
https://github.com/vit9696/AppleALC
Apple Alc not working....I put AppleALC.kext and Lilu.kext into Library>Extension.
Patch Audio layout 3 in DSDT but not working...please...Help
How I Find all this patch....
-FIX ERRORS AND WARNINGS
-HPET
-SATA
-DMAC
-SLPB
-DARWIN
-XHCI
-PLUGIN TYPE
-HDAS to HDEF
-HDEF
-RTC
-IRQs
-SBUS
-MIKEY
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-LAN
-USBX
-PMCR
-IMEI
-EC
-NVME
-ASMEDIA USB
-ARPT
-INTELHDGRAPHICS
-BATTERY
-PNLF
for test inject via clover and check what layout-ids work for ur audio codec
How to Patch HDAS to HDEF....
How I Find and download all the patches....
-HPET
-SATA
-DMAC
-SLPB
-DARWIN
-XHCI
-PLUGIN TYPE
-HDAS to HDEF
-HDEF
-RTC
-IRQs
-SBUS
-MIKEY
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-LAN
-USBX
-PMCR
-IMEI
-EC
-NVME
-ASMEDIA USB
-ARPT
-INTELHDGRAPHICS
-BATTERY
-PNLF
see the video about HDAS to HDEF
alc 255
