dedicahyadi Posted July 7, 2018 Posted July 7, 2018 Bro MaLd0n, i have tried to fix but not works. please help me to fix my clover and acpi, thanks in advance Send me Dedies-MBP.zip
Administrators MaLd0n Posted July 7, 2018 Author Administrators Posted July 7, 2018 Bro MaLd0n, i have tried to fix but not works. please help me to fix my clover and acpi, thanks in advance CLOVER.zip if have problem just drop edited DSDT press O key in Clover boot screen, go to Acpi Patching/DSDT Name and put DSDT02.aml -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
dedicahyadi Posted July 7, 2018 Posted July 7, 2018 if have problem just drop edited DSDT press O key in Clover boot screen, go to Acpi Patching/DSDT Name and put DSDT02.aml Thank for helping me sir, you are the man.
melbryanflores316 Posted July 11, 2018 Posted July 11, 2018 xts and config where i can find the config2.plist in http://Olarila.com/forum/viewtopic.php?f=51&t=6393 it seems that i dont have permission to download the attached files,
Administrators MaLd0n Posted July 11, 2018 Author Administrators Posted July 11, 2018 where i can find the config2.plist in viewtopic.php?f=51&t=6393 it seems that i dont have permission to download the attached files, u need type in clover boot option press O key/config and use config2.plist -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
melbryanflores316 Posted July 11, 2018 Posted July 11, 2018 oh i see, I'll let you know later if what's the result
melbryanflores316 Posted July 11, 2018 Posted July 11, 2018 try install with a minimum kexts and config btw what's the minimum kexts?
Administrators MaLd0n Posted July 11, 2018 Author Administrators Posted July 11, 2018 fakesmc and voodoops2 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
melbryanflores316 Posted July 11, 2018 Posted July 11, 2018 press O key/config and use config2.plist i cant find config2.plist in the clover Option menu(press O), config.plist is the only available in the list
melbryanflores316 Posted July 11, 2018 Posted July 11, 2018 Help me, this is the problem I'm facing right now. I'm using 10.13.6. config2.plist.. fakesmc and voodoo only in my kext this is the link of the picture https://imgur.com/a/Vyqm2gi link for my clover https://drive.google.com/open?id=18r862tyBddCrlbCsHSqvRozfMYeaIhUg
melbryanflores316 Posted July 11, 2018 Posted July 11, 2018 solved, in my bios, reset bios settings, boot-> disable legacy rom, enable legacy boot, ptt off virtualization off config2.plist
Administrators MaLd0n Posted July 11, 2018 Author Administrators Posted July 11, 2018 solved, in my bios, reset bios settings, boot-> disable legacy rom, enable legacy boot, ptt off virtualization off config2.plist good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
melbryanflores316 Posted July 11, 2018 Posted July 11, 2018 after I format my target drive and install it, when i restarted and boot in usb, and boot the target drive, installation get wrecked.. but i follow some tutorial in youtube. have to use config2.plist. and edit the boot args delete dart, and add -f after -v and after kext-dev-mode, add USBBusFix=Yes as of now the installation is ongoing about 6 minutes remaining, awhile ago when i dont edit the boot args, when installation is ongoing after how many secs the installation get wrecked
melbryanflores316 Posted July 11, 2018 Posted July 11, 2018 good btw sir what can you suggest about the sound,, i patched applehda, copy the patched in s/l/e and changed the audio in my config list after restart no audio yet
Administrators MaLd0n Posted July 11, 2018 Author Administrators Posted July 11, 2018 send me files RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rotoon Posted July 15, 2018 Posted July 15, 2018 Hi Sir, after i installed VoodooHda audio is not working ,and graphic showing wrong, It should be hd 630 This is my SEND_ME http://www.mediafire.com/file/6kjkp0hyhu55odh/Send+me+Nuttapons-MacBook-Pro.zip Thank you
Allan Posted July 15, 2018 Posted July 15, 2018 Did you had repaired the disk permissions after install the kexts? If not, do it with Kext Utility Thanks & Regards IdeaPad Gaming 3i • Aspire A515-52 • Clover / OpenCoreWe are in a great Forum, so, let's have some fun and learn from each other!
kimkimono1 Posted July 15, 2018 Posted July 15, 2018 Please Help. Thank you very much. Send me kimonomkprosmbp.zip
Administrators MaLd0n Posted July 15, 2018 Author Administrators Posted July 15, 2018 Hi Sir, after i installed VoodooHda audio is not working ,and graphic showing wrong, It should be hd 630 This is my SEND_ME http://www.mediafire.com/file/6kjkp0hyh ... ok-Pro.zip Thank you ur install, files is very dirt, very strange is hard to put good files and changes -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted July 15, 2018 Author Administrators Posted July 15, 2018 Please Help. Thank you very much. Attachments CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
kimkimono1 Posted July 15, 2018 Posted July 15, 2018 Stuck here http://picture.in.th/id/8a9c67e1617b0af25ad787f9b9926a7f
Administrators MaLd0n Posted July 15, 2018 Author Administrators Posted July 15, 2018 Stuck here http://picture.in.th/id/8a9c67e1617b0af ... f9b9926a7f first, press barspace and block lilu.kext and Intelfix kext if dont work u can drop a edited dsdt press O key in Clover boot screen, go to Acpi Patching/DSDT Name and put DSDT02.aml and remove file in clover/acpi/patched -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
kimkimono1 Posted July 16, 2018 Posted July 16, 2018 first, press barspace and block lilu.kext and Intelfix kext if dont work u can drop a edited dsdt press O key in Clover boot screen, go to Acpi Patching/DSDT Name and put DSDT02.aml and remove file in clover/acpi/patched Now I can boot in to Osx with HDD. Sorry for my English SPEC Lenovo y520 PROBLEM - intel graphic hd 630 7mb - intel wireless can't use
Administrators MaLd0n Posted July 18, 2018 Author Administrators Posted July 18, 2018 UPDATE FIRST POST -Clover folder -Patches -Mojave -Cosmetics -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
