58 minutes ago, admn wall said:
can you help me patch driver Nvidia GeForce 940mx? thank
optimus don't work. need disable nvidia and use only intelHD
ok intelhd to slowly , if upgrade to ssd and more ram this help to more fast ? thank
yes
but about video no
On 11/2/2020 at 7:41 PM, MaLd0n said:
yes
but about video no
hi i had problem cpu temperature to hot 80°C and restart suddenly, so any suggestion to reduce cpu temperature? thank
Hello,
my MacOS Mojave unable to boot. It was boot looping, few second after selecting MacOS it from Clover menu.
It failed to boot after a text shown "SMCRTC: Start", take a look at this pic,
this is my default boot arguments
I used config2.plist to boot from USB installation image for installing. I have followed the installation guide, except the "Embedded Controller Device"  because i use Mojave not Catalina. I pasted the NOTEBOOKS CHIPSET SERIES SKYLAKE+ Olarila EFI folder for my Kabylake laptop and finally the patched DSDT from you. So there is only 1 config.plist at the Clover folder.
Could you give the solution? thank you
17 hours ago, admn wall said:
hi when im reinstall catalina i had trouble with igpu is disabled. can you help me?
what hardware?
11 hours ago, MaLd0n said:
what hardware?
my hardware acer e5 475g intel hd i5 7200 ssd128gb with 12gb ram and my sound and my igpu is unable , [IGPU] graphics driver failed to load: could not register with framebuffer driver! can you help fix its? thank you maldon
config3.plist.zip
<key>PciRoot(0)/Pci(0x02,0)</key>
            <dict>
                <data>AADAhw==</data>
                <key>device-id</key>
                <data>FlkAAA==</data>
                <key>framebuffer-con1-alldata</key>
                <data>AQUJAAAIAACHAQAA</data>
                <data>AQAAAA==</data>
                <key>framebuffer-con2-alldata</key>
                <string>&lt;02040a00 00080000 87010000&gt;</string>
                <key>framebuffer-fbmem</key>
                <data>AACQAA==</data>
                <data>AAAwAQ==</data>
            </dict>
            <dict>
            </dict>
thank you maldon this work greak. and know i can fix brightness with brightness slider from appstore
https://www.olarila.com/topic/8930-guide-easy-brightness-hotkey-remapping/
6 hours ago, admn wall said:
i had just litte problem maldon, when im restart or shutdown sometimes stuck in apple logo and progress bar a half. what mean stuck in apple logo? but sometimes successfully login with full progressbar.
i know my problem is my ethernet because my Wifi driver is not connected but is ok for me
Post one Full Dump
https://www.olarila.com/topic/10301-olarila-runme-dumper/
https://olarila.com/files/Utils/RunMe.app.zip
Hello,
I have Intel core i5 7200u,
12GB DDR4 RAM,
Intel HD620,
Nvidia Geforce 940mx,
When I use attached EFI file for my Kabylake notebook from
 this url then stucked at Apple logo, but when I use EFI folder of USB stick then system boot successfully but Graphics, Audio, Wifi, Touchpad, etc is not working,
I tried patching graphic but doesn't work,
kindly help me fixing following issues.
Thank you in advance!
config.plist.zip
https://www.olarila.com/topic/6420-guide-mobile-intel-hd-graphics-clover-or-opencore/
