[ref]greedyman[/ref], try disable discrete gpu, use -wegnoegpu bootarg
Hello, I need some help with my Acer Swift 3 SF315-52-813L Notebook. Installing works, but after then, I can't have any acceleration of the iGPU and no WiFi.
Here the spec:
Intel i5 8550U
iGPU: Intel UHD 620
RAM: 8GB
Storage: 256GB SSD + 1TB HDD
OS: macOS Mojave
Send me DJHartys-MacBook-Pro.zip
[ref]YukuzaYin[/ref], nvme is native, idk what happens
Help me! Installation success, but stuck on Apple logo After replace Clover
Intel Core i5 7200u
Intel HD 620 + Nvidia GT920MX
Olá MaLd0n,
Estou com o mojave instalado e só faltou o ajuste de brilho e as informações de bateria. Testei os tutoriais indicados pra isso mas só dava kernel panic.
Reinstalei tudo novamente e gostaria de uma ajuda pra esses problemas.
Obrigado.
Send me wesleyjipa.zip
1 hour ago, wesleyjipa said:
Olá MaLd0n
3 hours ago, wesleyjipa said:
 audio parou
veja useful links na minha assinatura, audio é só injetar via clover/oc
2 hours ago, Francisco Nash Cardoso Junior said:
my processor is Kaby Lake gen
ACPI error, ae_bad_parameter. How to fix it?
u need check in logs and fix via dsdt
i'm trying but it in windows it doesnt have a way to edit this file... the error:
ACPI cannot parse/execution the following files:
_SB.BAT0._BST
_SB.BAT0._BIF
_SB.BAT0.ECBE
returned by: PCI0.LPCB.EC0.OperationRegion(ECXP, EmbeddedControl, Zero, 0xFF)
the method i found using rbwrite in windows(but i dont know how to edit this file):
Method(ECBE, 0, NotSerialized)
                Acquire(MUEX, 0xFFFF)
                Store("ECBE", Debug)
                Store(^^PCI0.LPCB.EC0.XIF1, Index(PAK0, One))
                Store(^^PCI0.LPCB.EC0.XIF2, Index(PAK0, 0x02))
                Store(^^PCI0.LPCB.EC0.XIF3, Index(PAK0, 0x03))
                Store(^^PCI0.LPCB.EC0.XIF4, Index(PAK0, 0x04))
                Store(^^PCI0.LPCB.EC0.XIF7, Index(PAK0, 0x07))
                Release(MUEX)
            Method(_BIF, 0, NotSerialized)
                If(ECON)
                    ECBE()
                Else
                    Store(0xFFFFFFFF, Index(PAK0, One))
                    Store(0xFFFFFFFF, Index(PAK0, 0x02))
                    Store(0xFFFFFFFF, Index(PAK0, 0x04))
                    Store("Error", Index(PAK0, 0x09))
                    Store("00000", Index(PAK0, 0x0A))
                    Store("Error", Index(PAK0, 0x0B))
                    Store("Error", Index(PAK0, 0x0C))
                Return(PAK0)
            Name(BFB0, Package(4) {Zero, Zero, Zero, Zero})
            Name(BCAP, 0xFFFF)
            Method(_BST, 0, NotSerialized)
                Store("BST1 Start", Debug)
                If(LEqual(^^PCI0.LPCB.EC0.BSOK, One))
                    Store(^^PCI0.LPCB.EC0.XST0, Index(BFB0, Zero))
                    Store(^^PCI0.LPCB.EC0.XST1, Index(BFB0, One))
                    If(LEqual(BCAP, 0xFFFF))
                        Store(^^PCI0.LPCB.EC0.XST2, BCAP)
                    Else
                        Store(Divide(Multiply(BCAP, 0x64), ^^PCI0.LPCB.EC0.XIF2, , ), Local0)
                        If(LGreater(Local0, 0x64))
                            Store(0x64, Local0)
                        If(LLess(Local0, Zero))
                            Store(Zero, Local0)
                        Store(Divide(Multiply(^^PCI0.LPCB.EC0.XST2, 0x64), ^^PCI0.LPCB.EC0.XIF2, , ), Local1)
                        If(LGreater(Local1, 0x64))
                            Store(0x64, Local1)
                        If(LLess(Local1, Zero))
                            Store(Zero, Local1)
                    Store(BCAP, Index(BFB0, 0x02))
                    Store(^^PCI0.LPCB.EC0.XST3, Index(BFB0, 0x03))
                    Store("BST1 End", Debug)
                Release(MUEX)
                Return(BFB0)
