[ref]ajimunir[/ref], replace dsdt in clover/acpi/patched
replace kext in clover/kexts/other
VoodooPS2Controller.kext.zip
extract new send_me after reboot
[ref]ajimunir[/ref], put it in ur desktop and run .command inside folder
[ref]fefortunato[/ref], DSDT.aml.zip
fefortunato,
(27.37 KiB) Baixado 2 vezes
Thank you, High sierra worked correctly, but there is a problem that persists in Mojave when activating the graphics, the mouse cursor is locked to the semovimenter, it is impossible to use the system, it knows some solution.
sorry for my bad english
[ref]fefortunato[/ref], no idea about it
[ref]MaLd0n[/ref], thanks for the patch, there is only one more problem in the high sierra, after logging in to macOS, a few moments later the keyboard stops working, any solution to this? is it possible to remove the patch from the keyboard and touchpad? because when I start the system without dsdt.aml the keyboard does not turn off and the touchpad works normally.
[ref]fefortunato[/ref], test without patches about keyboard and touchpad
[ref]MaLd0n[/ref], without the DSDT.aml the keyboard and touchpad works normally, can you do a DSDT.aml only without the keyboard and touchpad patches? can you help me? :)
[ref]fefortunato[/ref], extract new send_me with my files load, i need check
[ref]fefortunato[/ref], use a dsdt too and voodooi2c kexts
[ref]MaLd0n[/ref],
I'm still new to the subject, do I still use the DSDT.aml you sent me? I'm also using Olarila's CLOVER, does it already contain the kexts? right?
i have an laptop acer F5-573G-50KS wifi/bluetooth/940mx are not working i did something wrong? iam new to this hackintosh thing maybe I doesn't get all the steps to get it working tks, using mojave 10.14.5
[ref]tusamal[/ref], if u have a wifi intel, forget it, don't work
optimus don't work, forget nvidia
[ref]tusamal[/ref], not good, only cosmetic and little good patches
i tried everything but mac os setup is not detecting internal hdd of my laptop, and i don't think that it will detect an ssd if i put that in laptop because i think problem is caused by that sata mode which is set to RAID. thats not possible to change. so i tried to install on a usb 3.0 pen drive(64 gb) and it worked but main problem is that i can't permanently use that on a 64 gb usb drive.
