Administrators MaLd0n Posted April 4, 2019 Author Administrators Posted April 4, 2019 [ref]jcrcarmo[/ref], --Run_Me RunMe.app "> -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jcmrdc Posted April 5, 2019 Posted April 5, 2019 Hi MaLdOn I followed your instructions and here are the saved files from the RunMe.app (please refer to attachment). Thanks!! Send me JCs-MacBook-Pro.zip
Administrators MaLd0n Posted April 5, 2019 Author Administrators Posted April 5, 2019 [ref]jcrcarmo[/ref], DSDT.aml.zip enable EC0 to EC patch in config.plist -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jcmrdc Posted April 5, 2019 Posted April 5, 2019 EC0 to EC patch was already enabled in my config.plist. I installed your DSDT.aml to EFI... ACPI/Patched and I notice that now I have battery management and the brightness slider under system preferences works - this is a great improvement. Now, is there a way to make the brightness keys - and + work? Thanks a lot. I owe you a beer!
Administrators MaLd0n Posted April 5, 2019 Author Administrators Posted April 5, 2019 [ref]jcrcarmo[/ref], extract new send_me https://Olarila.com/forum/viewtopic.php?f=28&t=8396 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jcmrdc Posted April 6, 2019 Posted April 6, 2019 Hi MaLd0n, success!!! I saved the tutorial codes in Notepad in Windows and for some strange reason MaciASL doesn't read it when I copy and paste it in the patch window. I had to save the codes in rich text format first and then enter tem in MaciASL. Tricky... So I followed the tutorial again and voilá! My brightness control keys are working perfectly! Thanks for your time and help!
Administrators MaLd0n Posted April 6, 2019 Author Administrators Posted April 6, 2019 [ref]jcrcarmo[/ref], enjoy -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
murimoney Posted April 8, 2019 Posted April 8, 2019 I know I should run the runme.app, but i can't boot into mac osx no matter what I do. I have tried yosemite, el capitan, sierra, high sierra and mojave. Nothing works. Pls help me patch to disable nvidia graphics so I'll be able to boot high sierra installer and help me with other important patches. Here is my specs Razer blade 14 2015 4k display core i 7 4720HQ Intel hd 4600 and Nvidia 970m 16gb ram I hope you help me pls, I beg you. MaLd0n EFI.zip
Administrators MaLd0n Posted April 8, 2019 Author Administrators Posted April 8, 2019 [ref]murimoney[/ref], u need check what device we need disable DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
murimoney Posted April 8, 2019 Posted April 8, 2019 [ref]MaLd0n[/ref], Thank you for the DSDT patch. I was able to boot into high sierra install I downloaded from your site. I also used your clover for Notebookseries. After booting, graphics does not work as expected, but display was very laggy dragging and unusable to the point it got stuck. I was able to get the send me file, and I also included my clover folder. My laptop has a 4k screen with intel HD 4600 which I heard is very difficult to get a working graphics. I've set my DVMT to 96mb. I'll like to fix graphics before I move to other patches. Thanks for the help, and I'm sure to make a donation for the wonderful job you are doing here. Send me users-MacBook-Pro.zip
Administrators MaLd0n Posted April 8, 2019 Author Administrators Posted April 8, 2019 [ref]murimoney[/ref], Video https://Olarila.com/forum/viewtopic.php?f=62&t=9275 use it DSDT.aml.zip and it change EC0 to EC 4543305f 45435f5f -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
murimoney Posted April 14, 2019 Posted April 14, 2019 [ref]MaLd0n[/ref], Thank you for the help. Ive been reading for exams so I havent had time. I've finally figured out the graphics. The dsdt you se4nt me4 wouldn't boot my mackintosh anymore, maybe its because I made changes to my bios and my battery drains like crazy and my laptop gets very hot. Ive made another sendme file, and this time around, I would love it if you help me with the necessary dsdt patches (battery, display brightness, audio and the rest that are important. Thanks man, I love you!!! Send me users-MacBook-Pro 2.zip
Administrators MaLd0n Posted April 14, 2019 Author Administrators Posted April 14, 2019 [ref]murimoney[/ref], DSDT.aml.zip change EC0 to EC 4543305f 45435f5f -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
murimoney Posted April 17, 2019 Posted April 17, 2019 [ref]MaLd0n[/ref], Thank you for the DSDT patch. Sorry for the late reply, I've been having a terrible internet for 2 days now so I haven't done much, hackintosh-wise. Just to knote, I got mojave working on thesame laptop. Appstore doesn't work because I have no Ethernet hardware for this laptop (thanks to razer), and rehabman's fix doesn't work. Sleep is another thing for a cause of concern for me. After wake from sleep, keyboard stops working. Other than that, all other stuffs work. Including sound, brightness and the rest. thank you for all the help man.
Administrators MaLd0n Posted April 17, 2019 Author Administrators Posted April 17, 2019 [ref]murimoney[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ajimunir Posted April 22, 2019 Posted April 22, 2019 hey [ref]MaLd0n[/ref], can you help me to fix my dsdt. thanks Send me Ajis-MacBook-Pro.zip
Administrators MaLd0n Posted April 22, 2019 Author Administrators Posted April 22, 2019 [ref]ajimunir[/ref], 1- Replace/Put DSDT in Clover/Acpi/Patched DSDT.aml.zip 2- Install Clover again with correct options 3- Reboot 4- Extract new Send_me Last Clover Version UEFI USE VOODOOI2C KEXTS https://github.com/alexandred/VoodooI2C/releases -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ajimunir Posted April 22, 2019 Posted April 22, 2019 [ref]MaLd0n[/ref], i cant use my keyboard and mouse, but birghtness is worked, thanks so,i put that kext in clover or S/L/E? Send me Ajis-MacBook-Pro2.zip
Administrators MaLd0n Posted April 22, 2019 Author Administrators Posted April 22, 2019 [ref]ajimunir[/ref], 1- Replace Full Clover Folder CLOVER.zip 2- Install Clover again with correct options 3- Reboot 4- Extract new Send_me Last Clover Version UEFI -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ajimunir Posted April 22, 2019 Posted April 22, 2019 [ref]MaLd0n[/ref], still same Send me Ajis-MacBook-Pro#3.zip
