no idea
work very fine here
Hi, I need help.
My machine has the following Hardware.
Biostar H81a motherboard ver. 6.1
16GB 1600.
SSD 512bg
nvidia GTX 1650 4gb Video Card.
because of the video card I couldn't install the graphics accelerator, and the machine didn't work as it should. everything ran but it, how can I do it or what version can I install?
I appreciate the feedback.
this card is not supported
u need change
u need change
Thank you friend.
Can you tell me if another nvidia 820M is compatible, and from a Dell Nootbook I have, it works together with an intel HD graphics card.
model 14 3442-a40 series 3000.
it is an I5-4210U 1.70ghz core
8bg memory
250gb SSD
if you can give me more of this information, thank you.
See you.
u need amd card rx560+
Hello, Please help me.
I just follow your guide here to Install Mojave,
but after Boot MacOS from *diskname*, i got apple panic.
My Notebook Spec :
Lenovo Idepad 320-14ISK
CPU i3-6006U
RAM 8GB
GPU Intel HD 520
SSD 128GB
Thank You.
Edited by Makan Teman
try this folder. reset nvram one time
https://tinyurl.com/ax4c9e34
Hi, i am new to Olarila forum and a newbe hackintosh beginner, so please bare with me ;)
Ive got Dell XPS 13 9360 i5-7200U Kabylake FHD notebook / laptop that i would like to install High Sierra,  Mojave or Catalina,
for music production. so not intersted in Big Sur or bejound as not all audio soft is compatible.
What prebuilt image i should download and what additional files and or programs, where do i start?
thanks in advance
peace
