try
config.plist.zip
is just a new version of one kext
Thanks for the detailed guideline brother.
Can you help me to edit my DSDT attached here ??
check if work good
CLOVER.zip
send me dump after reboot
check if work good
Everything is working like a charm bro ... Only there is no brightness slider in display preferences... any thoughts?
188239359_ScreenShot2018-05-14at7_16_28PM.thumb.png.e5c7275f93dd3aa8bf0b797f3f39fad0.png
HP Pavillion 14-bf14080tx
Core i5 7200u
8gb Ram 2400ghz
Intel HD 620
256 ssd
High Sierra 10.13.4
send me new send_me
Here is the new send_me.
Please note that Internal speaker sound is low and baterry is draining like 1% per min ...
Also can't turn off Bluetooth....
u need check what ur audio codec
bluetooth is a kext, check it
CLOVER.zip
Thanks a lot bro.. Brightness slider is working ...
My Audio codec is ALC295 Layout 13 (not sure about layout).. After putting layout 13, it remains same (lower internal speaker)... I have even tried layout 3 and 28 ..same result ...
As I have not changed the intel wifi/Bluetooth chip, looks like bluetooth not gonna fully compatible ...
Core i5 7200u
8gb Ram 2400ghz
Intel HD 620
256 ssd
High Sierra 10.13.4
inject ids via clover now
use codec commander too
Should I install codeccommander though kext utility or just drop it to clover/kext/other ?? Downloded the codeccommander from here (attached image)
1468000486_ScreenShot2018-05-15at11_09_16PM.thumb.png.d2c9152676f85c6dc6bc1d98239e4e38.png
Core i5 7200u
8gb Ram 2400ghz
Intel HD 620
256 ssd
High Sierra 10.13.4
in clover/kext/other u dont need run nothing, just put kext there, reboot
Tried with layout 3, 13 and 28... but no luck.. same low sound... Thanks a lot bro... u helped me a lot...
Core i5 7200u
8gb Ram 2400ghz
Intel HD 620
256 ssd
High Sierra 10.13.4
try a applehda patcher by Mirone
It was running. Can you help me to edit my DSDT?
u have a full patched DSDT
