[ref]fefortunato[/ref], extract new send_me with my files load, i need check
[ref]fefortunato[/ref], use a dsdt too and voodooi2c kexts
[ref]MaLd0n[/ref],
I'm still new to the subject, do I still use the DSDT.aml you sent me? I'm also using Olarila's CLOVER, does it already contain the kexts? right?
i have an laptop acer F5-573G-50KS wifi/bluetooth/940mx are not working i did something wrong? iam new to this hackintosh thing maybe I doesn't get all the steps to get it working tks, using mojave 10.14.5
[ref]tusamal[/ref], if u have a wifi intel, forget it, don't work
optimus don't work, forget nvidia
[ref]tusamal[/ref], not good, only cosmetic and little good patches
i tried everything but mac os setup is not detecting internal hdd of my laptop, and i don't think that it will detect an ssd if i put that in laptop because i think problem is caused by that sata mode which is set to RAID. thats not possible to change. so i tried to install on a usb 3.0 pen drive(64 gb) and it worked but main problem is that i can't permanently use that on a 64 gb usb drive.
[ref]xdxjuniorxdx[/ref], first u need a correct config, check Olarila clover folder for ur chipset
[ref]xdxjuniorxdx[/ref], DSDT.aml.zip
[ref]Anon31415[/ref], u have a dsdt patched
Sorrry Im still new to this, how do I make my battery status work then?
I just used dsdt patch from page 4 in this thread, he had same computer as me, so its probably wrong I guess.
[ref]Anon31415[/ref], CHECK in rehabman repo, just apply
--Replace with my Clover folder
Download Clover Folder Notebooks Serie 100 200 300
--Install Sierra/High Sierra/Mojave and boot into system!
--Post Installation--
--Install Clover in HDD/SSD and replace with my folder
Can I use this for my System..?for Catalina. beta and upcoming Stable.
[ref]ALiveVam[/ref], catalina is very stable, beta 10
[ref]ALiveVam[/ref], if work in mojave, u can use in cata
