using current clover(not replace with 100.200.300)
the problem is inject kexts
the best is use all kexts in clover/kexts/other and option InjectKexts in config.plist
yes,
I checked kexts, all in clover/kexts/other
and option InjectKexts is 'Yes' in config.plist
sorry, I'm confused.
what u use for install kexts? don't use nothing, just put kexts in clover/kexts/other and reboot
kexts folder
config.plist
yes
but if u have kexts in system folder like l/e or s/l/e, use "detect"
any suggestion else?
u need check library/extensions and system/library/extensions
no 3rd kext in l/e and s/l/e
do you mean I must put kext into L/E or S/L/E?
no, the problem appears if u use kexts in clover folder and system folder
best is use all in clover folder and system stay clean
yes, I just use kexts in clover folder, no one 3rd kext in system folder
dell G3 3579
I have a lenovo ThinkPad T470s with Intel i7-7500U (Intel64 Family 6 Model 142 Stepping 9 GenuineIntel ~2703MHz)
Hey how I can know what I need beetween :
-Chipset Series 5, 6, 7, 8, 9
-SkyLake, KabyLake, CoffeLake
-SkyLake, KabyLake, CoffeLake Notebooks
-LGA775
THANK YOU ! :)
[ref]GroYOO[/ref], -SkyLake, KabyLake, CoffeLake Notebooks
Hi finally managed to install high sierra following your guide, but when i boot the installed OS i get this kernel error. Already tried the xhci kext with no luck. with the exception of the xhci kext my clover folder is exactly the same you provided on the first post.
thank you already
Hi MaLdon, How are you doing? I followed your tutorial and I was able to install the latest macOS Mojave on my Lenovo Ideapad 300 15isk laptop. I used CCC in order to run it in HFS instead of APFS. Now there are only a few minor post-install issues:
a) Since I copied the EFI folder from the USB install stick to the EFI on my HD, the very beginning of the boot process is visually very noisy, so how can I have it boot more quietly? Is it possible?
b) Could you please point me in the right direction to get my Function keys working?
c) Wi-Fi doesn't work yet. I'm waiting for my Broadcom card to arrive.
Thank you very much for all the time and effort you invest in helping the Hackintosh comunnity. Your work is greatly respected and appreciated.
Best regards,
Jay Cee. :)
[ref]jcrcarmo[/ref],
--Run_Me
RunMe.app
[ref]jcrcarmo[/ref], DSDT.aml.zip
enable EC0 to EC patch in config.plist
EC0 to EC patch was already enabled in my config.plist. I installed your DSDT.aml to EFI... ACPI/Patched and I notice that now I have battery management and the brightness slider under system preferences works - this is a great improvement. Now, is there a way to make the brightness keys - and + work? Thanks a lot. I owe you a beer! ;)
