hello Maldon I want your help ... realy .... i have assus strigx gl553vd can you see the specs please and tell me if is posible to oparate nvidia 1050 card? because i dont know how but i try a lots of times and my first problem is i cant mount efi partitsion . i dont car for the money just i want fix it if we can do something for ... i can do anything ;) something easy because i dont know how to fix this ... and to make my card work Thanks.
[ref]dmsdmsdms[/ref], if u have a optimus notebook, nvidia don't work, need disable and use intelhd
from bios i cant disable it ... this mean i can use only intel right ? and i have only 2 problems i cant mount my drive to do anything .... and i cant fix the sound ... you know something i can do for this? the sound is goood if we can fix it ...i put from file finder to change clover files from efi ... and i changet with this file you tell in your post... config2.plist
[ref]dmsdmsdms[/ref], --Run_Me
RunMe.app
[ref]MaLd0n[/ref], Hello mald0n, I found the reason for my ThinkPad x270 stop “end Randrom seed” (no “+” string).
As long as the Drivers64uefi in the Clover folder exists Fsinject-64.efi it will occur.
But without Fsinject-64.efi, then the kext in the other can not be loaded.
How do I solve this problem, or do I have to load the kext in the other without Fsinject-64.efi? Thank you!
[ref]origindevx[/ref], use kexts in library/extensions
Added in 11 seconds:
[ref]dmsdmsdms[/ref], https://Olarila.com/forum/viewtopic.php?f=81&t=6516
I have try this a lot of times and nothing . Also today I installe the Mojave and still I cant mount the efi... and I cant do anything for the sound ... just I tell for inform... I have 2 hdd in the laptop one ssd ... and one hdd in ssd have windows and in . Hdd macos ... you have any idea...;
[ref]dmsdmsdms[/ref], no idea, for efi is just install clover
[ref]origindevx[/ref], hard
my friend ... i try something else ... i leave only one hdd in my laptop nothing else ... and i instal clear tha high sierra from the start again and finally ... the sound works alone i dont do anything and just work :D ... this is enough for me i use it only for davinci resolve .... with internal graphic card is fine for me ...
[ref]bloodstream[/ref], DSDT.aml.zip
[ref]bloodstream[/ref], u can patch .aml or .dsl
my laptop is acer e5 476g
i5 8250U
12gb ram
i succeed installed mojave 10.14.3
after instaalation.. restart
and i got bootloop panic
i tried config and config2
please help
what i should do?
btw no problem with high sierra and mojave beta
thanks
Acer e5 476g
try with -x
@MaLd0n,
I want to install High Sierra to my Desktop PC
HP Pavilion 690-056ccn Gaming
mother board spec(H370): https://support.hp.com/tw-zh/document/c05991291
HP disabled BIOS Advance setting
and when GTX 1060 on board, UHD auto disabled, I must use Nvidia GTX 1060 as my video card.
First I use Clover.100.200.300 to install, but cannot boot into install interface.
So I find this clover(in Send me ...zip file) similar to my machine's configuration, it can boot into install, but install freeze at "2 minutes..."
Then I installed macOS through TimeMachine recovery, it can be booted.
But :
1. cannot power off except click machine's Power Button;
2. cannot sleep to wake.
3. System Information cannot get PCI information
4. cannot control light of screen.
Please Help me, thank you!
Send me iMac-HP.zip
I will replace clover using 100.200.300 to try it.
u can use ur clover folder, just add patches too
change GFX0 to IGPU
47465830
49475055
change HDAS to HDEF
48444153
48444546
change HECI to IMEI
48454349
494d4549
change SAT0 to SATA
53415430
53415441
change GLAN to GIGE
474c414e
47494745
using current clover(not replace with 100.200.300)
replace DSDT.aml with sending to me
and patched ACPI in clover configurator
but it cannot boot up.
