ford2201 Posted April 7, 2018 Posted April 7, 2018 what? not signal intel-high-definition-audio not save see singla audio all alc i IDT all audio
Administrators MaLd0n Posted April 8, 2018 Author Administrators Posted April 8, 2018 THE TOPIC IS FOR SKYLAKE, KABYLAKE OR COFFEELAKE! -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
justmex Posted April 12, 2018 Posted April 12, 2018 so where is the guide for second generation intel CPU laptops
Allan Posted April 12, 2018 Posted April 12, 2018 so where is the guide for second generation intel CPU laptops http://Olarila.com/forum/viewtopic.php?f=50&t=6255 Thanks & Regards IdeaPad Gaming 3i • Aspire A515-52 • Clover / OpenCoreWe are in a great Forum, so, let's have some fun and learn from each other!
artur-pt Posted April 12, 2018 Posted April 12, 2018 hello what about ? install clover without uefi option , just choose a boot file to ur system and try to boot good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
justmex Posted April 12, 2018 Posted April 12, 2018 how do i do this from windows 10? is there a macOS image DMG i can use to boot the laptop? ie booting macOS from USB FDD?
artur-pt Posted April 12, 2018 Posted April 12, 2018 hello men what are u doing here .. this forum is to read about ur issues http://Olarila.com/forum/viewforum.php?f=51 if u don't like to read what the ppl write here and in ever hackintosh forum .. sorry .. hackintosh is 99 % reading, googling, persistency and 1% of luck u have compatible hardware .. or u buy a Mac and ur problem is solved good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
Administrators MaLd0n Posted April 25, 2018 Author Administrators Posted April 25, 2018 UPDATE FIRST POST -Clover folder -Kexts -Patches -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ford2201 Posted April 28, 2018 Posted April 28, 2018 why do they suspend the system and hackintosh from PC and laptop as to repair everything that has been caused
Administrators MaLd0n Posted May 11, 2018 Author Administrators Posted May 11, 2018 Help me. CLOVER.zip replace, reboot and send me new SEND_ME -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
gasaxsaxsax Posted May 11, 2018 Posted May 11, 2018 CLOVER.zip (2.24 MiB) Downloaded 2 times replace, reboot and send me new SEND_ME I can't boot mac with it.
Administrators MaLd0n Posted May 11, 2018 Author Administrators Posted May 11, 2018 I can't boot mac with it. post one photo -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted May 11, 2018 Author Administrators Posted May 11, 2018 Attachments IMG_0002.png (1.24 MiB) Not viewed yet try config.plist.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
gasaxsaxsax Posted May 11, 2018 Posted May 11, 2018 try config.plist.zip (5.21 KiB) Downloaded 1 time I tried, but it's still the same, I think it is still an old config file.
Administrators MaLd0n Posted May 11, 2018 Author Administrators Posted May 11, 2018 is just a new version of one kext -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
nazibhasnain Posted May 15, 2018 Posted May 15, 2018 Thanks for the detailed guideline brother. Can you help me to edit my DSDT attached here ?? Send me Nazibs-MacBook-Pro.zip HP Pavillion 14-bf14080tx Core i5 7200u 8gb Ram 2400ghz Intel HD 620 256 ssd High Sierra 10.13.4
Administrators MaLd0n Posted May 15, 2018 Author Administrators Posted May 15, 2018 Thanks for the detailed guideline brother. Can you help me to edit my DSDT attached here ?? check if work good CLOVER.zip send me dump after reboot -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
nazibhasnain Posted May 15, 2018 Posted May 15, 2018 check if work good Everything is working like a charm bro ... Only there is no brightness slider in display preferences... any thoughts? HP Pavillion 14-bf14080tx Core i5 7200u 8gb Ram 2400ghz Intel HD 620 256 ssd High Sierra 10.13.4
Administrators MaLd0n Posted May 15, 2018 Author Administrators Posted May 15, 2018 Everything is working like a charm bro ... Only there is no brightness slider in display preferences... any thoughts? send me new send_me -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
nazibhasnain Posted May 15, 2018 Posted May 15, 2018 Here is the new send_me. Please note that Internal speaker sound is low and baterry is draining like 1% per min ... Also can't turn off Bluetooth.... Send me Nazibs-MacBook-Pro.zip HP Pavillion 14-bf14080tx Core i5 7200u 8gb Ram 2400ghz Intel HD 620 256 ssd High Sierra 10.13.4
Administrators MaLd0n Posted May 15, 2018 Author Administrators Posted May 15, 2018 Here is the new send_me. Please note that Internal speaker sound is low and baterry is draining like 1% per min ... Also can't turn off Bluetooth.... u need check what ur audio codec bluetooth is a kext, check it CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
