[ref]ElPingU[/ref],
plugin type?
Mald0n,
I do not understand your question ..... if you refer "plugin type" to what patch i'm using in order to inject the patches to the audio device ... let me tell you ..... :-)
I was under the impression that DSDT files will patch all your system devices ..... jejejeje I can see is not like that !!! I added your DSDT file on my Clover/patches folder and stil no audio .... Then I went ahead and download the latest version of AppleALC.Kexts and placed on the kexts folder (other) and edit plist on clover folder using ID 12 - 7 - 3 - and so on ... still no luck !!!
So far that's what I was doing ...
Any advice on that ???
[ref]ElPingU[/ref], change layout-id in DSDT
can you help me ? i install mac os high seira in asus zenbook pro ux501 vw i7 6700hq , 12Gb ram ddr4 , hd530 , gtx960m (disable) , when i plug hdmi external display good work, but when i boot systems in built-in monitor not working and stay in dark or progress bar apple logo , please help me❤️
u need check if exist one patch for u, if no u can read some info here
https://www.insanelymac.com/forum/topic/324503-dual-screen-not-working/?tab=comments#comment-2445773
[ref]artin[/ref],
tnx dear maldin :guitar
Added in 7 minutes 4 seconds:
dear maldon i can't solve my problems , plase help me few hours after i sent in this topic my files witht your app in files folder , please check it and help me , God bless you bro :superman
[ref]artin[/ref], u need check patch for u about video and apply in config.plist, is a personal patch
Mald0n,
I reinstall Everything from scratch again and now ....
1) After Clover installation and addition of your DSDT file system hangs on rebooting "apfs_vfsop_unmount:1941: all done. going home. (numMountedAPFSVolumes 0)
done
perhaps i have to add this on a different place, not here.
Mald0n,
done
The main reason that I reinstalled everything was cause I was having warnings on the DSDT recompile file, once i made the changes on the layout-id and trying to recompile a lots of warnings coming out not making possible the id change ......
warning is nothing, just ignore
mojave installer is not detecting my internal hard drive... only external drive(usb) is visible in Disk utility
Laptop Acer swift 3 i5 8250U + nvidia mx 150
Wd hdd, no ssd
sata mode is RAID in bios. there is no option to change that from bios.
plz help
idk, need check if have a solution for it, i think yes
[ref]MaLd0n[/ref], please help me patch, how don't know how to do it.
-FIX ERRORS AND WARNINGS
-HPET
-SATA
-DMAC
-SLPB
-DARWIN
-XHCI
-PLUGIN TYPE
-HDAS to HDEF
-HDEF
-RTC
-IRQs
-SBUS
-MIKEY
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-LAN
-USBX
-PMCR
-IMEI
-EC
-NVME
-ASMEDIA USB
-ARPT
-INTELHDGRAPHICS
-BATTERY
-PNLF
Thanks FOR YOUR HELP... :help:wallbash
Send me proowebwrites-MacBook-Pro.zip
[ref]murimoney[/ref], DSDT.aml.zip
:guitar[ref]murimoney[/ref],
is there any solution, i also tried sierra. it boots into installer but doesnt detect my internal drive. and high sierra installer is givin error related to discrete graphics while booting into installer.
