On 4/10/2020 at 6:49 AM, foka756 said:
Hello, ... Tell me what's wrong?
check Olarila folders for start a clean config
11 minutes ago, zbajatovski said:
need help updating el cap to sierraSend me.zip
how to fix ATI 4850 521mb gfx
idk about this gpu, but i think is work
10 hours ago, foka756 said:
Hi. Check for what?
renames, etc
Olá, boa noite a todos.
Já tive o HighSierra instalado no meu hack e por que já tinha outro HD com o Sierra com os programas que mais usava deixei de lado o HighSierra.
Hoje separei um SSD e parti para instalar o High Sierra, não fui pro Mojave porque minha placa de vídeo não suporta.
Mas esbarrei num problema, durante a instalação ela para e reboota o computador, e até onde consegui ver é por unsupported CPU.
Estou tentando com a versão que baixei hoje aqui do site, High Sierra 2020 Olarila RAW com o flashdrive criado no balena etcher.
Como disse já tive o HS instalado e hoje tenho o Sierra mas quero fazer esse pequeno upgrade numa instalação limpa.
O Processador é um Core2Quad (Q9550) numa Gigabyte EP45-UD3R
Grato por qualquer ajuda
Hacks:
Main:
Gigabyte Z390 Gaming X  - Intel i5 9400F - 16 GB DDR4 2666 - Radeon RX 570 4GB - Tahoe 26.0.1
Backup: Gigabyte EP-45-UD3R - Intel Core2Quad 9550 @4.0Ghz - 8 GB DDR2 - GeForce 9800GT - Sierra
Hello MaLd0n. I am currently on High Sierra and have your DSDT and other fixes in place. I am getting ready to do a clean install of Mojave on the same PC with different drive and a different graphics card. Current card is 8800gts, new card is GTX650. Do I have to get a new DSDT made and do I need to change anything in clover / EFI?
Thanks!
Z77 Build= Quad Boot Win 10, Win 7, Mojave, Kali Linux (learning). 2x NVME drives, 1X Samsung EVO SSD, 1X 16GB USB 3.0 (Kali) 1X 1TB WD storage drive, GTX770, 16GB Gskill ARES,
Work in progress1: P35-DS3R,  Xeon 3360 @3.2GHz. 8GB ddr2 800, Tri-Boot system.
Work in progress2: G31M-ES2L, Q9650 @ 3.2GHz. 4GB ddr2 800, Tri-Boot system
Waiting on case for next build.....
Fiz um quote do meu próprio post porque consegui algum avanço.
Eu creio que é algo das opções do boot do clover + arquivos.
Primeiro tentei dar boot pelo HD do Sierra, que puxou o Clover de lá e consegui chegar na tela do install. Mas parou a instalação restando 11 minutos e com cerca de 1 cm de barra preenchida.
Ai observei as opções do Clover e vi que não tem a que deixa o meu sistema bootar lá, debug=0x100
Com essa flag o sistema foi pelo proprio flashdrive até onde nao estava indo mas ficou sem video. Nova tentativa mandei injetar Nvidia, chegou no installador, vamos ver o que acontece.
Edit, parece que travou no mesmo ponto anterior.
Edited by asapreta
Esqueci detalhe.
Hacks:
Main:
Aparentemente com as mexidas que dei está funcionando. Apesar de ter o kext da placa de rede (8111) na pasta KEXTS/OTHER da EFI a mesma não funciona/carrega.
Queria rodar um pouco o sistema sem trazer meu dsdt para cá para ver a performance, o Sierra anda lento demais em transferencias de arquivos
Hacks:
Main:
no, same files
19 minutes ago, MaLd0n said:
no, same files
Thank you!
Bem, quando eu coloquei o SSD de volta dentro do computador (mantendo a mesma porta SATA) parou de funcionar.
E quem disse que eu consegui reinstalar fazendo o mesmo processo.
Tive que inclusive refazer o pendrive pois depois da instalação ele não instalava de novo.
São coisas que eu não consigo entender mesmo.
Ai fica dando agora o Disk I/O error (que não deu da outra vez) - que é característico do ICH10
Ai dando um jeito para bootar (nem sei se o que está fazendo efeito é o Kext antigo o AppleAHCIPort na pasta L/E do pendrive ou a parte do fiz do ICH10 dos patches que coloquei no config.plist (apesar de não aparecer lá no clover na parte correspondente.  Mas os ícones ficam laranja.
Agora porque eu não consigo mais instalar com apenas a inserção do debug=0x100 e o inject Nvidia me intriga muito
Até porque eu quero testar justamente performance dos HDDs em transferencia de arquivos, o que está matando o uso do meu Sierra.
Hacks:
Main:
On Gigabyte G31m-ES2l with GTX650 (Kepler) Mojave Installer completes, system reboots and all is fine,   Clover loads up, Mojave starts up verbose and just before the Apple logo starts It reboots. No error message or anything. Why?
Does it with -x, with or without inject NVIDIA.
Edited by shabaa
On 5/6/2020 at 9:31 PM, shabaa said:
no, same files
Why?
2 hours ago, shabaa said:
GTX650 (Kepler)
650 is native, dont need inject nothing
u try it?
1 hour ago, MaLd0n said:
u try it?
Yes... no difference. Still rebooting just after end of verbose load of OS
with -x boot is fine? the problem is just a gpu?
Does same thing with- x boot flag.
Not sure but I am gonna try another drive tomorrow morning . Something just doesn’t feel right.
13 hours ago, MaLd0n said:
u try it?
Yes... no difference. Still rebooting just after end of verbose load of OS. Installed on brand new drive. No difference. Just rebooting at the point that the Apple is supposed to come up
