Dominik13 Posted January 21, 2020 Posted January 21, 2020 U need check about enable ur gpu In Clover settings? What should I try?
Administrators MaLd0n Posted January 21, 2020 Author Administrators Posted January 21, 2020 In Clover settings? What should I try? first check google -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zevs83 Posted January 31, 2020 Posted January 31, 2020 Hi all, as this is my first post in Olarila.com I would like to say first a big hello to everyone. I followed the guide and got Mojave installed, telemetry plugin changed, boot from SSD with LGA775 folder, masterhibernate and mater-disable command. This is my configuration: - Asus P5Q pro turbo - Intel Q9400 - MSI Nvidia gtx 780ti - 16gb of ddr2 ram The graphics card is fully recognized OOB (brand, GPU model and all 3gb of VRAM), but the system is very laggy. That's strange because for a moment is working perfectly after it gets stuck on the rainbow circle, then working again for a bit, then stuck again, etc etc. It is unusable like that. I did a lot of searches, tried many patches in clover configurator, tried to install High Sierra, tried another graphics card (Asus GTX 760), but the result is still the same: lags. The zip file generated by "runme.app" is available at the following address: http://s000.tinyupload.com/?file_id=36269766214053671486 the file was generated on a clean installation (Olarila Mojave) as I said above before explaining the configuration. I didn't include the kext for LAN and Audio coming from my old Yosemite installation and perfectly working. Many thanks in advance for your help, Vince
Administrators MaLd0n Posted January 31, 2020 Author Administrators Posted January 31, 2020 Hi all DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zevs83 Posted January 31, 2020 Posted January 31, 2020 Dear Maldon, many thanks for your quick support. I've just tried your DSDT but no luck with the lag issue. I just noticed the system boot time is shorter than before (If I'm not wrong that's because you fixed some error into the original DSDT). I can't really understand why I've got lags: what I suspect is the cpu not properly used by the system or the vram recognized but not fully working......but.....lilu and whatevergreen are in there, the lga clover folder is in there, the telemetry has been changed.......can't understand Any idea? Many thanksssssss!
Administrators MaLd0n Posted January 31, 2020 Author Administrators Posted January 31, 2020 Dear Maldon extract new send_me with my dsdt -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zevs83 Posted February 1, 2020 Posted February 1, 2020 Thanks, it is here: http://s000.tinyupload.com/?file_id=12415882289512750415 Fingers crossed
Administrators MaLd0n Posted February 1, 2020 Author Administrators Posted February 1, 2020 Thanks, it is here take one shot, backup and remove AppleGraphicsPowerManagement.kext, rebuild, reboot and test -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zevs83 Posted February 1, 2020 Posted February 1, 2020 take one shot, backup and remove AppleGraphicsPowerManagement.kext, rebuild, reboot and test Hi MaLd0n, thanks for the trick. I removed AGPM from S/L/E, then rebuilt the kernel cache and rebooted. The system is slightly better but I still have lags In the meantime I tried to change also the smbios from imac10,1 to macpro3,1 (which is the one that I used to have in Yosemite for this machine), I can say as a macpro3,1 I have the feeling that the system is working better than imac10,1 but lags are still there. Any thoughts? Thanks!
sgrunt12002 Posted February 19, 2020 Posted February 19, 2020 (edited) Hi I have Mainboard Pegatron G41 ICH7/R, CPU Intel Core2 Quad Q8300 socket 775/LGA, Ram 4Gb DDR3, Graphics AMD Radeon HD 5700. Without uefi bios Which is the maximum macos versionthat i can install? and which guide should I follow? Thanks for your help Edited February 19, 2020 by sgrunt12002
Administrators MaLd0n Posted February 19, 2020 Author Administrators Posted February 19, 2020 20 minutes ago, sgrunt12002 said: Hi I have Mainboard Pegatron G41 ICH7/R, CPU Intel Core2 Quad Q8300 socket 775/LGA, Ram 4Gb DDR3, Graphics AMD Radeon HD 5700. Without uefi bios Which is the maximum macos versionthat i can install? and which guide should I follow? Thanks for your help u can try a high sierra, i think ur processor have a mandatory instruction -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
sgrunt12002 Posted February 19, 2020 Posted February 19, 2020 (edited) Thanks for your reply. Mine is a Mobo Bios, I'll install clover according to your guide. Do I still have to copy the EFI folder to /Volumes/EFI before installing clover? Thanks Edited February 19, 2020 by sgrunt12002
IgnacioDN Posted February 19, 2020 Posted February 19, 2020 I can't install High Sierra or Mojave because appears it and the pc restarts G31M3 V2 C2D E7300 8600 GT 2GB RAM
Administrators MaLd0n Posted February 19, 2020 Author Administrators Posted February 19, 2020 27 minutes ago, IgnacioDN said: I can't install High Sierra or Mojave because appears it and the pc restarts high sierra + need some extra processor instruction -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Guest Vince Posted March 7, 2020 Posted March 7, 2020 On 2/1/2020 at 2:29 PM, zevs83 said: Hi MaLd0n, thanks for the trick. I removed AGPM from S/L/E, then rebuilt the kernel cache and rebooted. The system is slightly better but I still have lags In the meantime I tried to change also the smbios from imac10,1 to macpro3,1 (which is the one that I used to have in Yosemite for this machine), I can say as a macpro3,1 I have the feeling that the system is working better than imac10,1 but lags are still there. Any thoughts? Thanks! Hi All, after weeks of trying every solution I have sorted out the problem: as I suspected the problem was the CPU. I've just installed Sierra and the computer is fast an performant out of the box. I have just two minor issues: - the firewire port is recognizing the audio card only if I turn it on before starting macos (or if I reboot), before was not like that. However.......I've noticed the same issue in windows so the problem is probably a faulty firewire interface in my audio card - I've got 2 usb expansion cards on the slots PCI, one is a USB 2.0, the other one is a 3.0. With Yosemite they where both working good, in Sierra they are working just with usb storage devices. Any other device is not recognized. The USB ports on the mainboard are working perfectly. I have increased the USB limit and tried the USBinjectall.kext but they still are not working. Am I missing some step? Thanks all!
philippe dumoulin Posted March 22, 2020 Posted March 22, 2020 hello MaLdOn, i have this config: MB intel DG41RQ with last bios CPU intel Xeon E5450. 4x3ghz 2 x 2gb DDR2 800mhz Radeon HD6670 1gb DDR5 I installed high sierra and upgraded to 17G10021 without having put the HD6670 card. the problem comes when i want to install the HD 6670 card, the pc hangs no way to pass. if I start a new installation with the HD6670, it blocks directly. I tried a DSDT that you made on the forum for another person, but that did not change anything. my config,plist : smbios imac 10.2 or imac 14.2 no change can you help me for this problem ? best regard Phil
Administrators MaLd0n Posted March 22, 2020 Author Administrators Posted March 22, 2020 1 hour ago, philippe dumoulin said: MB intel DG41RQ with last bios need check what best fakeid for ur gpu -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
foka756 Posted April 9, 2020 Posted April 9, 2020 Hello MaLd0n! Sending to you my files. Thank you for your kind attention. Send me Mac-Pro-f756 2.zip
Administrators MaLd0n Posted April 9, 2020 Author Administrators Posted April 9, 2020 1 hour ago, foka756 said: Hello MaLd0n! u used many clover acpi patches -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
foka756 Posted April 10, 2020 Posted April 10, 2020 (edited) 16 hours ago, MaLd0n said: u used many clover acpi patches Hello, ... Tell me what's wrong? Also I loose usb connection after sleep... Thanks in advance Edited April 10, 2020 by foka756
