[ref]GabyTrifan[/ref], Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here
[ref]GabyTrifan[/ref], use it with folder for lga775
[ref]GabyTrifan[/ref], clover/acpi/patched
Alguém que possa me ajudar a instalar o OpenCore como Bootloader no lugar do Clover?
Minha placa mãe é uma p5g41t-m lx2/br
Se eu conseguir, vou comprar um Core2Quad pra ela, mas por enquanto tô usando ela com um E4400
[ref]Sepphiroth[/ref], não tem pq vc usar opencore, vc pode usar os drivers do opencore no clover, isso sim
https://github.com/ReddestDream/OcQuirks
eu queria usar para testes, aprender a montar o OpenCore... peguei esse setup antigo pra aprender mais, sem precisar estragar meu sistema na maquina que uso todo dia, mas tô vendo que no OpenCore eu vou ficar pra traz mesmo, o Clover leva vantagem em sem bem mais fácil e já vir com tudo quase pronto
Does anyone have any success installing catalina on lga 775? I couldn't get it to install. Always stuck at disk utility not showing any disk at installer. Already trying MaLd0n giuide to patch appleahci in clover but still no success.
My spec is asrock g41m-s3, xeon l5420, 8gb ram dual channel, 1 ssd, 2 hdd, nvidia gtx 650
[ref]yanotnubie[/ref], g41/ich7 simple don't have ahci option in many cases, i think the problem is that
yanotnubie, g41/ich7 simple don't have ahci option in many cases, i think the problem is that
Ah I see. So the maximum mac version is mojave with patch and ootb is high sierra then?
[ref]yanotnubie[/ref], u can try use a dosdude tools
I have MSI G41M-P33 Combo and no ethernet, sound and only use internal graphics motherboard. Any help me?
lan, use a old version from kexts in el capo
audio, use alcid=x in bootarg
Are there any HD7750 users here? I have a strange bug with my Sapphire HD7750 1gb on Mojave. I am only able to boot into safe mode without graphics acceleration. When I use the boot arguments "-lilubetaall radpg=15", only a mouse cursor appears on the corner and it disappears from time to time. It is weird because my HD7750 even worked with my AMD FX processor with a kernel patch. Is there something specific about HD77xx series and LGA775 or do you think it is due to my current config?
Hello! I installed High Sierra successfuly on my PC but when I try to first boot i’m greeted with a black screen. Before that the only thing I can see is Unsupported CPU and PCH. My CPU is Intel Core 2 Quad Q9500,AMD Radeon HD 6570. I can boot only with safe mode and my nvram gets recognized which is 2 gigs.
AMD Radeon HD 6570
U need check about enable ur gpu
