redjulius Posted December 4, 2019 Posted December 4, 2019 u can use efi folder How? I'm not really new to this but years ago it was easier not hehehehehe
Administrators MaLd0n Posted December 4, 2019 Author Administrators Posted December 4, 2019 [ref]redjulius[/ref], https://Olarila.com/forum/viewtopic.php?f=28&t=8222 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
redjulius Posted December 4, 2019 Posted December 4, 2019 It is in full installation, the installer starts well, I can format the partition but when it starts to install it gives me the error, this https://Olarila.com/forum/viewtopic.php?f=28&t=8222 can I do it to usb after burning it?
redjulius Posted December 6, 2019 Posted December 6, 2019 redjulius, viewtopic.php?p=83664#p83664 Hello I hope you are well, a question if I do it as that guide serves me with El Capitan too or should I download other specific files? like this https://www.insanelymac.com/forum/files/file/426-el-capitan-mbr-patch/ Added in 7 minutes 43 seconds: redjulius, u can use efi folder With this you tell me that I can edit the .raw to put the clover folder specific for LGA 775 or CHIPSET SERIES 5, 6, 7, 8, 9?
Administrators MaLd0n Posted December 6, 2019 Author Administrators Posted December 6, 2019 [ref]redjulius[/ref], yes, just rename .raw to .dmg and edit -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
redjulius Posted December 7, 2019 Posted December 7, 2019 (edited) At last! I could do it only by changing the date of the Bios to the departure date of El Capitan but nothing else, I already installed the Clover with the LGA 775 folder, but when I try to boot from the disk I get a TSCSync error, which I can block in the installer, but with the clover on the disk it doesn't appear to me, another thing is that the G.Chrome blinks when I move the mouse over it. Can anyone help me? Edited December 12, 2019 by Guest
redjulius Posted December 7, 2019 Posted December 7, 2019 another thing is that the G.Chrome blinks when I move the mouse over it. I correct, the entire El Captain blinks, both in the Chrome window and in Launchpad
Jadepilot64 Posted December 8, 2019 Posted December 8, 2019 can I get my dsdt patched and my clover folder edited and any way to get the gma 4500 working in macos as i don't have dedicated graphics card Please find the attachments https://drive.google.com/open?id=1LEB4CRwMhcxZ26Vjs49HRewuVq63wfOn regards
Administrators MaLd0n Posted December 8, 2019 Author Administrators Posted December 8, 2019 [ref]Jadepilot64[/ref], gpu don't work under osx, forget it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Tazorro Posted December 11, 2019 Posted December 11, 2019 Hi MaLd0n, I managed to successfully install High Sierra on this configuration Asus P8H61-MLX3 PLUS R 2.0, I3 2130, 6Gb of ram and Asus 6670 1gb. Can I try to upgrade to Mojave or Catalina? Thanks for your help
Administrators MaLd0n Posted December 11, 2019 Author Administrators Posted December 11, 2019 [ref]Tazorro[/ref], need check if ur gpu work under catalina -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
redjulius Posted December 12, 2019 Posted December 12, 2019 I correct, the entire El Captain blinks, both in the Chrome window and in Launchpad with this i mean please
yanotnubie Posted December 14, 2019 Posted December 14, 2019 Hey @MaLd0n, yesterday I tried to install Catalina but on disk utility it doesn't show any SSD nor HDD. On High Sierra it's shown and I can install HS. Mobo Asrock G41M-S3 Bios 1.60/latest, 1 ssd (sandisk), 2 hdd (seagate and wd), using default config no added kext or others, just disable voodootscsync. Any advices?
Administrators MaLd0n Posted December 14, 2019 Author Administrators Posted December 14, 2019 [ref]yanotnubie[/ref], try it Find --> 40600200 Replace --> 00000000 AppleAHCIPort -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
yanotnubie Posted December 14, 2019 Posted December 14, 2019 Thank you. Just to be sure, it's AppleAHCIPort.kext right? Where it's located? On USB there's only Install MacOS Catalina. But when I open package content there is no S/L/E. Just InstallESD and bunch of others files. Or am I done wrong steps? Also I've red some comment that on lga775 systems needed to replace apple telemetry with one from HS, is it true?
Administrators MaLd0n Posted December 14, 2019 Author Administrators Posted December 14, 2019 [ref]yanotnubie[/ref], is a KextsToPatch patch -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
yanotnubie Posted December 14, 2019 Posted December 14, 2019 yanotnubie, is a KextsToPatch patch Ah I see. Will try it tomorrow morning. Thank you MaLd0n.
GabyTrifan Posted December 23, 2019 Posted December 23, 2019 Hi, I tried to install El Capitan but after I start installing on HDD it suddenly stops and says that I can't install Mac OS. I have Mobo MSI Boston , WD HDD and Nvidia Gt710. Using VESA on GPU (NVdisable=1) because otherwise I get DSMOS and vodootscsync is disabled
Administrators MaLd0n Posted December 23, 2019 Author Administrators Posted December 23, 2019 [ref]GabyTrifan[/ref], check logs -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
