[ref]mauma[/ref], create one usb stick with dosdude patch
I found an os x mountain lion installation and I used it with maverics, after a thousand ups and downs (the bios was reset and more ...) now makes the first update. With High Sierra I had made a jam with the guides but it was successful. For now, thanks for the help
Hi MaLd0n, I managed to successfully install High Sierra on this configuration Asus P8H61-M LE / USB3, I3 2130, 8Gb of ram and Gt 8800 512MB. I would like to optimize some details ... The clover home screen I would like to take it to 1920 x 1080 is now low resolution, it will be a 1024x 768. The second thing is the Windows disk is read as Legacy HD1 you can change the name? Thanks for your help.
[ref]Tazorro[/ref], live it with, is just in boot
[ref]Tazorro[/ref], have one driver csm for legacy, but is not good idea, cause many problems
I noticed that using the video outputs of the motherboard the solution is perfect. unfortunately the HD 2000 has no kext and in the end I can have a 1080 resolution but only 4mb of video card.
Hi MaLd0n,
I am stuck at booting after installation Mojave using your image method
CPU : E5440
Motherboard : ASUS P5G41T-M LX
GPU : HIS RX 470 IceQ X2 TURBO 4GB
i am able to boot and install by disabling VoodooTSCSync and changed the SMBIOS to Mac 13,1 and use this viewtopic.php?f=62&t=6639
i'm connecting the monitor to onboard graphic if i connect to rx 470 it goes black screen
the problem after installation is i got black screen when boot to mac
sorry for bad english
hope you can help, thanks in advance :guitar
[ref]vrecetex[/ref], rx4 or 5 serries is a uefi card, for legacy need some extra way
[ref]surfermax[/ref], :shock:
tenho um problema depois as istallaçao de high sierra 10,13.4 minha voodoohda não funciona ,não tenho audio. outra coisa não consigo ativar a aceleração video da geforce 1050 ti . instalei vanila con orilla e Clover . u config.plist. coloquei em efi para Asus 775 aquele consillhado da vc. outra coisa e' que não consigo fazer carbon Copy com highsierra porque disk utility não format outra ssd que eu tenho no hardware. serra por causa do disk em afs ?
minha Asus p5qd turbo ,geforce 1050 ti , ssd 750 samsung ,ssd crucial
[ref]surfermax[/ref], tem de instalar os rc scripts pra nvram funcionar, o nvidia web driver precisa disso
[ref]surfermax[/ref], nesse caso sim
resolvi também o com voodoohda 282 obrigado por sua ajuda deu certo !!! ultima coisa tenho. uma duvida se usar ou não o master-disabler .command e u disablehibernate.command e onde posso abaixar isso? :D
Added in 2 minutes 2 seconds:
vc sabe pq high Sierra não reconhece as outra Back-up do Yosemite e não consigo fazer carbon Copy do disk com highsierra?quero migrar para outro disk ssd maior
:crazy:
