Administrators MaLd0n Posted September 1, 2019 Author Administrators Posted September 1, 2019 [ref]newinnov[/ref], use imac10,1 smbios -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
newinnov Posted September 2, 2019 Posted September 2, 2019 Thanks Maldon, I was using iMac 10,1 smbios only , Since start. But after boot keyboard mouse didn't work . Also my graphics card does not work while dsdt is active, otherwise it works fine(ati injection+ frambuffer patch)
once Posted September 22, 2019 Posted September 22, 2019 Hey MaLd0n can you do an edit for me. My specs if it matters: ASUS P5QC Intel® Xeon® CPU E5450 @ 3.00GHz NVIDIA GeForce GTX 1050 Ti Thanks! Once-Send me iMac.zip
Administrators MaLd0n Posted September 22, 2019 Author Administrators Posted September 22, 2019 [ref]once[/ref], DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Pentejo Posted September 28, 2019 Posted September 28, 2019 Hello, I finally have installed High Sierra with your Image on my P5Q3 deluxe mobo, have all done like described. The Problem is my GeForce 8400 GS nVidia Graphic card does not work. I only can boot with nv_disable=1 and get 1280x1024 resolution (not enough for me). It was working properly in Yosemite 10.10.5 after unishit Install. When I inject nVidia in Clover I alwas get crashes on Boot. Any Suggestions? How get higher Resolution?
Administrators MaLd0n Posted September 28, 2019 Author Administrators Posted September 28, 2019 [ref]Pentejo[/ref], my Suggestion: new gpu xD one simple GT9800 work very good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Pentejo Posted September 29, 2019 Posted September 29, 2019 Hi MaLd0n, thx for your suggestion. Finally I got it to work properly on my olds system nVidia_8400GS_HighSierra.rar
Administrators MaLd0n Posted September 29, 2019 Author Administrators Posted September 29, 2019 [ref]Pentejo[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
tuliodomingos Posted October 8, 2019 Posted October 8, 2019 Me ajuda tenho rx560 shappishe pulse com placa 775 foxxconn processador xeon 5450 não estou conseguindo aceleração na rx 560 no Mojave e nem catalina obtive sucesso só sierra 1
newinnov Posted October 9, 2019 Posted October 9, 2019 newinnov, use imac10,1 smbios Sadly, provided DSDT was bad. It never worked.I'm not using any DSDT fix except "FixDisplay" in clover acpi. Google led me to this 8 year old dsdt , which works fine after recompiling with macias - https://www.osx86.net/files/file/1543-dg41rq-dsdtaml/ I'm attaching here, so that other users with same board may reference it. But this dsdt gives restart or grey screen on monitor after wake from sleep, all other things work fine. MaLd0n, your dsdt does not have SBUS and some other code. Can you please let me know what diffs are necessary to fix sleep issue? Thank you. (I'm attaching both DSDT, your's one is titled DSDT_MaLd0n ) DSDT_DG41RQ.zip
Administrators MaLd0n Posted October 9, 2019 Author Administrators Posted October 9, 2019 [ref]newinnov[/ref], DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
newinnov Posted October 10, 2019 Posted October 10, 2019 Thank you very much. It worked. But sleep issue still remains, on sleep only monitor goes off, all USB ports, fan and cpu remains active
papahonda2019 Posted November 3, 2019 Posted November 3, 2019 Hi, I've tried to install the Olarila Mojave image to my old PC. It's a Core 2 Duo E6750 2.66GHz and NVIDIA GeForce GT 520 on Asus P5KC crossflashed to P5KR. After burning the image to USB flash, I booted and managed to reach the clover but every time I hit the "boot with the selected options", it always restarts. I've checked verbose and block VoodooTSCSync.kext. My current OS is El Capitan 10.11.4 (15E65) and it's working fine. I need to upgrade to at least Sierra due to app compatibility. Would you please tell me what should I do to make this work? Thank you...
Administrators MaLd0n Posted November 3, 2019 Author Administrators Posted November 3, 2019 [ref]papahonda2019[/ref], sierra need sse4,1, check ur processor spec -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
papahonda2019 Posted November 3, 2019 Posted November 3, 2019 sierra need sse4,1, check ur processor spec Hi MaLd0n, thanks for the reply. Oh my bad.. I knew it's not supported, but I thought you've created some kind of patch for that when I see LGA 775 is supported by Olarila. Is it going to work if I replace the processor with the modded Xeon and keep using my mobo? Or what's the best option for me to install newer macOS than El Capitan? Thank you...
dickymuliafiqri Posted November 8, 2019 Posted November 8, 2019 I'm trying to install Catalina, but at Disk Utility is show nothing except my USB Stick Installer (No SATA Drive/Hard Disk) LGA775 C2D E8500 Nvidia GT710 (Kepler)
nvanh1804 Posted November 24, 2019 Posted November 24, 2019 Hello Can you Patch this for me??? My problem: -Audio ALC888s not working - Shutdown problem Thanks a lots http://s000.tinyupload.com/index.php?fi ... 5208159095
Administrators MaLd0n Posted November 24, 2019 Author Administrators Posted November 24, 2019 [ref]nvanh1804[/ref], wrong link -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
nvanh1804 Posted November 25, 2019 Posted November 25, 2019 Please help me to patch this. I'm so sorry with the wrong link yesterday File: http://s000.tinyupload.com/index.php?file_id=00387732148795171956 Thanks for your help!
Administrators MaLd0n Posted November 25, 2019 Author Administrators Posted November 25, 2019 [ref]nvanh1804[/ref], check other topic, use only one, ur dsdt edited is there -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
redjulius Posted December 2, 2019 Posted December 2, 2019 Hello Good afternoon, the installer starts on two PCs (Gigabyte GA-G31M-ES2l integrated VGA and Foxconn H61mxe DVI for GeForce 210) but after the installation starts I get an error "No packages suitable for installation have been detected" I attach the photos:
Administrators MaLd0n Posted December 2, 2019 Author Administrators Posted December 2, 2019 [ref]redjulius[/ref], burn Olarila image again -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
redjulius Posted December 2, 2019 Posted December 2, 2019 redjulius, burn Olarila image again Ok, I'm downloading it again, I had downloaded it from Mavericks and burned it to a usb with Balena Etcher, then moved it to another hard drive to format the Mavericks with the Olarila El Capitan, but I think the .bz2 was damaged so like the .raw. I will wait, I will burn it with the win32 from Windows 10 and hopefully I will answer you from Olarila El Capitan, Thank you.
Administrators MaLd0n Posted December 3, 2019 Author Administrators Posted December 3, 2019 [ref]redjulius[/ref], u need extract .bz2 to .raw before burn -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
redjulius Posted December 3, 2019 Posted December 3, 2019 redjulius, u need extract .bz2 to .raw before burn Of course, I downloaded it again, I unzipped it with 7-Zip, I burned it with Win32, all good, but I still get the error "No packages suitable for installation have been detected"
