chipset is not intel, but i think work good
Hi MaLd0n, you hearten me. Unfortunately, it is days that I try to install but without success. The installation hangs on changing the config.plist on these errors:
pci configuration begin or on mcache: 4 cpu (s). Help me
extract dsdt with f4 key in clover boot screen, files generated in clover/acpi/origin
Hello Maldon, I enclose the original folder with the two config. that I used. I followed the procedure to create the usb El Capitan with Etcher and iso Olarilla. I receive an infinite loop with default config and file creation with f4. If I replace with my config receiving the error (pci configuration begin) but with f4 it does not give me any file in the folder.
Thank you so much if you can help me.
origin.zip
the problem is ur chipset, is not intel, need check what need for boot it
the tables is ok
what do you advise me to do? Change motherboard? I have a p5kpl-am I can put the cpu and the video card. On this but 'I found problems on the network card and audio.
[ref]Tazorro[/ref], p5kpl-am is good
Then change and let you know. Do I have to make some changes to the config when I install the 6870 hd? For the problem related to the network card that I mentioned before? Thank you very much for helping.
[ref]Tazorro[/ref], u need check what lan card u have?
[ref]Tazorro[/ref], work
[ref]Tazorro[/ref], ;)
El Capitan installation succeeded perfectly. I have to tell you that I tried to install High Sierra and Mojave but nothing, he says it's not supported. He does nothing.
If you can help me with finishing.
It does not connect to the internet: instead of eth0 I Built-in Port tries to connect but disconnects.
On system preferences it does not give me any kind of iMac.
Thank you
[ref]Tazorro[/ref], --Run_Me
RunMe.app
[ref]Tazorro[/ref], DSDT.aml.zip
use smbios iMac10,1
use DPCI manager and check a correct lan card
[ref]Tazorro[/ref], clover/acpi/patched, reboot
hello Maldon, I tried everything last night until now, trying all the kekts possible not to bother you but the network still does not work. I also tried to insert them in the system / library / extensions nothing to do.
do you have any suggestions?
Thanks again
[ref]Tazorro[/ref], extract new send_me with last files
