[ref]TomP[/ref], looks good, shutdown work? several problems with shutdown in old giga mobos
[ref]MaLd0n[/ref], shutdown does not work with this configuration. It works when I load Mojave using clover from an EFI folder of another SSD where I have Sierra installed, with no use of DSDT. I attach Send.me file using that configuration (where shutdown works without DSDT), can you find out which options enable shutdown? Do you think it's OK to use this configuration for Mojave as well as Sierra or should I change some options in my previous configuration? Clover version is the same (4910).
Send me user1s-imac.zip
[ref]TomP[/ref], u try a iMac15 smbios with my configs?
Added in 7 minutes 39 seconds:
[ref]pikardx[/ref], DSDT.aml.zip
[ref]TomP[/ref], in old config u use a shutdown fix by clover
I use the clover shutdown fix in both configs. Only works in one...
[ref]TomP[/ref], TRY, FRWR REMOVED, TESTED IN MY LGA775 AND WORK, SHUTDOWN BLOCK BY FRWR DEVICE
[ref]MaLd0n[/ref], disabling FireWire solved the shutdown issue (along with some random stalling and beach ball turning)!
Only thing remaining is the sleep issue, but I can live without it ?
[ref]TomP[/ref], k
enjoy
[ref]applestasteok[/ref], vmware don't need
Ah, yeah sorry. I just realized that a few minutes ago. I am waiting on Mojave to download, then I'll flash it to the usb and boot its to a single Hard drive partition 2 (windows is installed on partition 1).
If it boots and if i can install Mojave, I will run the "runme.app" and send you the new file.
Thanks for all your hard work and effort by the way. You're awesome man.
boot into
I'm getting a panic at the boot screen.
I have not yet been able to install Mojave Olarilla onto SSD.
(Also SSD is freshly formatted and decided not to use dual boot.)
"Please go to https://panic.apple.com to report.."
I'm installing Mojave olarilla image with flashed Clover to USB drive using olarilla app.
Motherboard G41MT-S2PT
CPU: Q9650
GPU: GTX 750TiSc
Help please.
Thank you.?
[ref]applestasteok[/ref], post one photo, error screen
Update.
I even tried using Sierra Olarila image and it was even worse.
All I got was an empty black screen, with about 12 or 13 asterisks "*******" on the top left corner of the screen/monitor, then it reboots back to clover boot.
G41MT- S2PT motherboard (ICH7)
Intel Q9650 CPU (quad core)
GTX 750Ti SC graphics card PCiE16
DDR3 1333mhz Ram
Do you need another file?
[ref]applestasteok[/ref], the images work for many, if don't work for u, u need check what cause it
Hello, I am a noob trying to install Mojave on this LGA775 PC
Please send config, I am getting a black screen with MSI Radeon HD 7770 1GB
Motherboard is Asus P5G4IC-M LX
CPU is Xeon e5450
Last message I can see in log is "unkown GPU" or something like that.
I cannot see the install screen after this, the kexts lilu and whatevergreen don't work with or without bootflags radgp=15 -lilubetaall deinit or injection
[ref]vmoney88[/ref], use -x to disable some drivers like video etc
Hi, I managed to install High Sierra on ssd (apfs), motherboard ga-ep35-ds3 with core2quad q9560, 6gb ram, gtx 970. pity that with the ssd I made a disaster ..... through app on os x I recovered everything and saved on folder. The big Testdisk sees everything but does not restore partition apfs..sigh sigh .. I follow your guide (os x ... sierra, high sierra 775), load base bios, I modify only SATA AHCI Mode - AHCI and save. Start from usb and then .... it panics. I only replaced the gtx970 with its gt8600. error occurs however, I do not modify boot clover only present -v (verbose mode) .The heat makes me bang my head in the wall ahahahah :wallbash:frantics:wallbash
