Post by MaLd0n » 21 Jan 2019, 21:37
cumpadi,
(7.01 KiB) Downloaded 2 times
my nephew told me that the hackintosh is starting again after turning it off and from time to time the mouse (usb mouse) does not work. Stay still. You must restart / reset Hackintosh to have the mouse work again. Can you please take a look at this DSDT?
Thank you
10.15.1 NvmeM2 SSD 500 GB X570 Aorus Elite - Ryzen 7 5800X - 32 GB DDR4 3600 MHz - Radeon RX 580 8GB
10.15.7 SSD120 GB GA-EP45T-DS3R - 16 GB DDR3 1600 MHz - GTX 760 2GB.
[ref]cumpadi[/ref], need check what cause it
Im triying to install high sierra on a ep43 ds3l but get a voodootscsync Kernel panic, how can I disable the kext before booting?
Hi, I have tried to install many times Mac OS on my old PC. It has an Intel Core2 Duo E6750, a Biostar G41D3C, a Nvidia 550ti and 4GB of RAM.
I have the Olarila Mac Os Sierra image but none of the boot args I used get me passed some errors:
I don't have a Mac and I don't know anyone who has one.
What should I try or is it even possible to get get a Hackintosh with my hardware? Thanks
[ref]ELBo[/ref], post one photo, kp screen
[ref]MaLd0n[/ref], You have posts for everything hahaha cool.
Well, this is with the default boot args
And this with some boot args I found for a similar build: -v npci=0x2000 GraphicsEnabler=0 nv_disable=1
[ref]ELBo[/ref], if ur processor don't have sse4,1, use el capitan
[ref]ELBo[/ref], sierra+ need a sse4.1, mojave need a sse4.2
Hi, I have already listened to this discussion and it happens that my CPU type is the same as FilthyJaxx from here https://Olarila.com/forum/viewtopic.php?t=6256&start=140
Following are the specifications of my computer
CPU: Intel ® Core 2 Quad CPU Q8200 @ 2.33GHz
MB: ASUS P5KPL AM-SE Bios Version 0702
RAM: 4GB DDR2
HDD: 250GB Seagate
GPU: Sapphire Pulse RX560 128Bit DDR5 2GB - NO OC
I successfully installed Olarila high quality 10.13.6
but I experienced a black screen problem after entering the login page and I tried to remove the graphics card and managed to enter the login page
is this problem located on lili.kext + WhatEvergreen.Kext ??????
I use the clover file fromlarilla for LGA 775 and the results are still the same, I have to remove the graphics card to be able to enter the login page
sorry my english is very bad, hope you can understand it
THANK YOU
[ref]imran.dim[/ref], check about RX5xx in legacy mode, is a UEFI cards, u need extra way
Hi MaLd0n, Thank you for responding. I have found a problem with the graphics card that I am using (Sapphire RX560 2GB 128Bit DDR5). The problem is only in the configuration in the bios, for now the graphics card can function normally on the Windows operating system. Next I will try in High Sierra. Is that possible ???
[ref]imran.dim[/ref], yes, u need use other rom with legacy support, RX560/580 is a uefi cards, don't work native in legacy mobos, in need a extra way
Mald0n, what things do I need to prepare to start installing High Sierra on this Asus P5KPL AM-SE motherboard ???
Do I have to make a usb installer on macOS ???
Or maybe you can recommend the macOS version that is suitable for this motherboard !?
[ref]imran.dim[/ref], Olarila Images
[ref]imran.dim[/ref], if ur processor have a sse4.1, yes
Mald0n, Sorry, I don't really understand hardware specifications, maybe I should try it first so I can know
I use a Prosesor Intel® Core™2 Quad Q8200 Cache 4M, 2,33 GHz, 1333 MHz FSB
Added in 40 minutes 2 seconds:
[ref]MaLd0n[/ref], I faced a black screen problem after the installation was complete. What ways should I do to overcome this problem?
Please help me :wallbash:wallbash:wallbash
Thank you for this guide!
I installed Mojave 10.14.4 on a socket 775 board (Gigabyte GA-P35-DQ6) with a Xeon X5460 CPU (SSE 4.1) modified for socket 775, and a Nvidia GTX 960 graphics card. Install went smoothly, on a WD SSD converted to AFPS (needed to disconnect all other drives first, ended up connecting the SSD with a USB adapter to overcome the "resources not found" error, after that everything was fine). Before booting from the SSD (which I had installed internally again) I replaced the com.apple.telemetry.plugin in S/L/UserEventPlugins with the one from High Sierra 10.13.6. After that Mojave booted flawlessly from the SSD with your 775 clover folder. Only thing I changed was SMBIOS to iMac 14,1. Everything works (full metal support with GTX 760 working OOB in dual DVI monitor setup, audio, ethernet), except sleep (computer shuts down completely). Can you please help me fine tune my system? I would appreciate a DSDT and config.plist suggestions. Thanks again!
Send me user1s-imac.zip
[ref]TomP[/ref], DSDT.aml.zip
SLEEP in ur case with wrong smbios etc for work in Mojave don't work good in some cases
[ref]TomP[/ref], extract new send_me with my dsdt
