[ref]PTE69[/ref], use npci=0x2000 and try other fakesmc version too
[ref]bor72[/ref], DSDT.aml.zip
CHECK OUR CLOVER FOLDER FOR LGA 775, USE IT
Finally install Mojave but have problems with my and radeon r9 270x (id 0x68111002) im using clover from Olarila for 775 sockets+fake id (0x68101002),fix display,lilu+green in other, than i have only 7mb of ram.Please help me
[ref]bor72[/ref], U can try with radpg=15, but idk, never use this GPU
Hi there,
I tried watching the YouTube tutorial for the LGA775 but unfortunately it seems like it was removed ...
After making the boot-able USB stick, I tried booting from the USB but I get a black screen with a '-' on the upper left corner and nothing happens afterwards is there something that I can do ?
I'm not sure if I'm doing something wrong or some of my hardware is not compatible ....
What settings do I need to change in the bios ?
My setup is :
Motheboard : Gigabyte GA-G31M-ES2C
CPU : Xeon x5460
GPU : GeForce GT 730
Ram : 2GB
[ref]Salsacock[/ref], High Sierra? install clover for legacy
ok, thanks ,use raspy=15,result-nothing
Added in 1 minute 41 seconds:
maybe to try add real id of my gnu (not fake id)in drivers 4000 and 7000?
MaLd0n, I'm trying to install Mojave and not High Sierra...
I didn't understand the part about installing clover for legacy, I'm not sure where to install clover, and I don't understand what does legacy mean ...
ur mobo is not UEFI
use it
I’m so confused, what I tried to do is install moiave from a bootable usb stick.
Here is what I did from the begining : download majave final and then made a bootable usb stick for mojave afterwards I tried booting from the USB and I get stuck on a black screen.
After seeing your reply I downloaded clover and made a bootable clover usb and I tried booting into mojave from there but I get the same black screen or a screen with a Forbidden sign in the center.
I’m not sure what else to do, is there something that I need to change in clover boot settings (args) or something that I need to change in the bios ?
[ref]ColaCoca[/ref], use high sierra, for mojave u need a some changes
"Youtube MacOS Install Guide Olarila" is dead (Video unavailable
"Hackintosh Guide - MacOS In..." is no longer available due to a copyright claim by Apple Inc.)
Please re-upload this video to another site, so we can download it then play
[ref]sabbirbd[/ref], i'll update in next week
ColaCoca, use high sierra, for mojave u need a some changes
Well, I downloaded High Sierra and used etcher to make a bootable USB and I was able to boot into it and I think I began the installation and then it crashes :
https://gyazo.com/3d534ff36070e32074468bf657d6fd51
https://gyazo.com/16033d112ee5fc7495d6aae7c7f62a62
What do you think I should do ??
My hardware :
CPU : Xeonx5460
RAM : 2GB
[ref]ColaCoca[/ref], i think is a sata problem, g31 is a simple ich7 and don't have AHCI option
u can try other usb port too
ColaCoca, i think is a sata problem, g31 is a simple ich7 and don't have AHCI option
I'm not sure I understand, What do you mean a sata problem, what does it mean AHCI ??
For now I will try an other USB port and tell you what happens ...
ahci is a sata mode mandatory for OSX, but g31/ich7 chipset don't have this option, but work in many cases
Using a different USB port solved the problem.
So at least it could work ??
Well , now I booted into the installation of the Hackintosh, and I get to the part where I have to choose a drive to install the Hackintosh on, but for some reason my drives/hard drives never show up not even in the disk utility (I did click on the show all drives/disks), What can I do ??
Edit : I did try removing all the old partitions on the hard disk and re-formatting it, but nothing worked.
