[ref]falkortv[/ref], send me files
RunMe.app
[ref]falkortv[/ref], try DSDT.aml.zip
put in clover/acpi/patched and reboot
extract new SEND_ME after reboot
I can’t send, USB 2.0 not working
MSI GV62-7RD 10.13.6 and W10(i5-7600HQ, 8GB DDR4, 240GB SSD + 1000GB HDD, Intel HD620)
Asus P7P55D-E 10.11 and W10(i5-760, 6GB DDR3, 320GB For Hackintosh, MSI GTX 960 Gaming 2G)
Fujitsu D2841-A11 GS3 10.13.6 - Mounting Hackintosh Custom Build (C2D E8500 3.16Ghz, 4GB DDR2, 250GB HDD)
[ref]falkortv[/ref], u boot from hdd/ssd or USB?
try with usbinjectall
USBInjectAll.kext.zip
Boot From Clover USB. I change MainBoard to Fujitsu D2841-a11 GS 3 and USB Working, I do not have more strength to play with Asus
This kext is on Clover from Olarila HighSierra Image, and don't work on ASUS.
Fujitsu D2841-A11 GS3 Send_me file: http://www.mediafire.com/file/u5eg7u7o0g54afi/Send+me+Fujitsu.zip
[ref]falkortv[/ref], u need boot from hdd/ssd, and don't use usbinjectall, ur usb is native, usbinjectall only if need
falkortv, u need boot from hdd/ssd, and don't use usbinjectall, ur usb is native, usbinjectall only if need
I Used Fujitsu D2841-A11 GS3 Mainboard and working usb native. Asus it will go to the garbage
Fujitsu D2841-A11 GS3 Send_me file: http://www.mediafire.com/file/u5eg7u7o0g54afi/Send+me+Fujitsu.zip . You can create me DSDT?
[ref]falkortv[/ref], DSDT.aml.zip
Okey, copy DSDT and run runme.app - http://www.mediafire.com/file/u6p452kk9f1ez8v/Send+me+iMac-FalkorTV.zip
Fujitsu D2841-A11 GS3(aka Esprimo P3520) have Audio Realtek ALC663 and LAN Broadcom BCM5784M, i can run Audio and LAN on Hackintosh?(Audio on AppleHDA Patcher is for Laptops - versions v1 and v2)
From DPCIManager is -
Audio Devices: 0x808627D8 Sub 0x17341166 nad 0x10DE0BEB sub 0x145834FC
LAN - Vendor 14E4 Device 1698 Sub Ven 1734 Sub Dev 1165
On Fujitsu mainboard only working 2 first USB, USB 3-4 and 5-6 don't working on MacOS(On bios and Windows working)
[ref]falkortv[/ref], use smbios iMac10,1 and -no_compat_check bootargs
falkortv, use smbios iMac10,1 and -no_compat_check bootargs
I change and add bootargs https://www.mediafire.com/file/pbh1ucr0z4qbfke/Send+me+iMac-FalkorTV.zip , but only the first 2 USB works.
EDIT: Working 2 on back, and 2 on mainboard port
[ref]falkortv[/ref], try with clover usb fix, config.plist/acpi tab
I cant even Boot USB thru Olarila Mojave 10.14.1, tried CLOVER.LGA775 instead default USB's EFI Clover and it worked.
But in Installation after selecting language a restart msg appeares.
this version of macos 10.14.1 could not be installed on this computer. Restart.
I tried manually patching insanlymacs https://www.insanelymac.com/forum/files/file/944-mojave-mbr-hfs-firmware-check-patch/ but does not works, shows same msg above.
ASUS P5TMGLX (legacy BIOS, NON efi)
C2D E8500
GeForce GT 710 2GB
[ref]FZSX[/ref], the best for ur hardware is avoid mojave
FZSX, the best for ur hardware is avoid mojave
Hey @MaLd0n, please dont go by, User Profile Config.
Ive Succesfully ran El Capitan to High Sierra on this config with dual boot windows 10, MBR partition scheme HDD.
Config:
ASUS P5G41T-M LX (legacy BIOS, NON efi)
Core2Duo E8500 3.16 GHz
Gigabyte GeForce GT 710 2GB v2.0
If mojave still cant run, thats ok.
If i missed somethin, or need more info do reply.
Thanks for ur help. :cap
[ref]FZSX[/ref], Mojave work, but need a little tricks, the best is high sierra
post ur files here
RunMe.app
[ref]FZSX[/ref], DSDT.aml.zip
[ref]MaLd0n[/ref],
I changed SMBIOS Clover config.plist to iMac 13,1 and got succesfully installed macOs mojave 10.14.1, but black screen after boot.
Moved some graphics kext(see pic)(ignore windows), got white screen with mouse cursor locked/freeze at top left corner. help!
Top of all keyboard dosent works in sierraa/mojave clover menu
