Need Help I'm not able to update 10.13.2 to 10.13.3
I am having trouble I am trying to update High Sierra from 10.13.2 to 10.13.3 and 10.13.0 to 10.13.3 but failed so many times. I have tried from Combo Update and from App Store but while installing it restart all the time but I have updated 10.12.2 to 10.12.6 with same config and works fine but not happening with High Sierra.
I am attaching my Debug file it would be grateful if some one help :D I am attaching the Debug files from both Sierra and High Sierra
High Sierra_debug_1451.zip
HackBook Pro :-HP DV6-6121 TX (Win 10 Pro + macOS 10.13.6 + OC )
Hac Pro:-GA-B365-D3H, Core i5 9440F AMD RX 580 8 GB (Win 10 Pro + macOS 10.15.7 + Big Sur Beta )
Hac Pro:-z97 sabertooth mark 2, Core i7- i7 4790k with GT 740 2GB and 32 GB Ram (OC+Catalina)
iHack:- Assus M2N68-AM-SE2,AMD Athlon+LE-1640,250 SSD ,4GB DD3 800MHZ Nvidia 9400GT (win 10 and 10.9.5+10.10.5)
iHack:-GA875M-D3H ,core-i5 3250,NVDIA 610-2GB 27"LED,8GB DDR3 1600mhz, (Only 10.10.5+10.11.6 with CLOVER)
iHack:-GA-78LMT-S2PT ,AMD Phenom II-X2 560,Radeon 6770 1 GB ,onboard Radeon HD 3000 not tested 4 GB DDR-3 1333 MHZ (10.11.6+Win 10 pro) Special thanks....  To Genius donovan6000 For Mode Bios (WiFi +BT Whitelist removed) & Amazing Hackintosh Guides and tutorial and much more visit this blog Hackintosh Mumbai
have a photo with screen error?
No i can't take picture because while installing it restarts everytime and I can't see any error
what graphics are u trying to use to install ?
what is switchable ? u can select in bios what card to use ?
if not u must use hd 3000 .. only that one works
google about hd 3000 .. u can do it here .. or other places
I am having dual graphics Intel hd 3000 + amd 6770m but I have disabled amd from bios. And I am using Intel hd 3000 and works gr8 from lion to high Sierra never have issue of graphics. But on high Sierra only one issue that is unable to update neither from combo nor from app store ....
ur lappy is not sandy bridge with 7 series motherboard chipset ?
if so try apply from rehabman hd3000 for 7 series chipset in ur dsdt
why u don't inject the kext from clover folder /other ?
