macOS on Minisforum N5 Air with Radeon Pro WX 2100
Hello,
I want to install macOS on a Minisforum N5 Air
The cpu is an AMD Ryzen 7 255 with Radeon 780M
I have installed this graphic card : AMD Radeon Pro WX 2100
It has 16 Go DDR5
There are a NVMe SSD Samsung EVO.
I use the Olarila EFI OpenCore folder for AMD
I have added the graphic card as a VGA Controller with OpenCore configurator
and added the patches for the AMD cpu.
I can boot to OpenCore and boot macOS installer but it is stuck at the begining
Thank you if you can help me 🙂
Edited by mapomme
