USB problem Asus P8Z77-v LK after install GTX 970
Hi Olarila Lovers.
I need some help.
I construct my new hackintosh.
i5 3570k + asus p8z77-v LK + GTX 970.
I recently buy the Nvidea GTX 970 and after insert it on my hackintosh i enable nvidea using the webdrivers.
The problem is: after insert the nvidea on my PC after boot some usbs not working on sierra 10.12.3.
Some USB 2.0 and 3.0.
I have no 3thy USB kexts installed, using default system drivers and until insert Nvidea all working ok.
After attach it at my motherboard it boot with no Graphics acceleration( of corse because no drivers installed or nvidea injected), but i saw that some usbs are not working, just because i pluged it.
Somebody can help me, because i don't know what nvidea can interefer at my USB.
So i attach my files:
-Original DSDT extrated by clover F5
- Pachted DSDT with MACIASL and asus source
-Sendme zip.
Some replys are very appreciated.
Best Regards, Nuno
Files.zip
UR MOBO
Intel® Z77 chipset: *4
4 porta(s) USB 3.0 (2 no painel traseiro, azul(s), conectores internos para mais 2 porta(s))
Intel® Z77 chipset:
10 porta(s) USB 2.0 (2 no painel traseiro, preta(s), conectores internos para mais 8 porta(s))
ASMedia® USB 3.0 controller: *4
2 porta(s) USB 3.0 (2 no painel traseiro, azul(s))
for asmedia, u can try genericusb, but only two ports
https://bitbucket.org/RehabMan/os-x-generic-usb3/downloads/RehabMan-Generic-USB3-2015-1215.zip
Thanks for your work MaLd0n.
After get the "login window" the USB2.0 take around 5seconds and start serivce and get usbs working.
USB3.0 starts at bios system and not disable during boot like usb2.0 and at login window the service ubs are working and i can insert password without need wait 5 seconds to service start.
Keeps without 2x usbs 3.0 non working, that board have 4 usbs 3.0 but with your fix just 2 are working and more 2x USB2.0
So if no other way to get all usbs working, with 2x usb2.0 and 2x usb3.0 is enough :D :D :D
Thanks a lot for your work!! :D, but i don't understand way inserting the GTX970 cause USB BUG... very strange :shock::shock::shock::shock:
send me ioreg
IORegistryExplorer 3.app.zip
i dont like fakesmc sensors, many bug, if u like use intel monitor
Intel® Power Gadget v3.0.3.dmg.zip
run Olarila command for rebuild
Olarila.command.zip
Very nice!
HDMI audio work?
use it, fakesmc mod for load LMU/Als0 patch
FakeSMC.LMU.zip
i apply many cosmetics too, in About This Mac / Pci
Check
Thanks a lot MaLd0n.
About the HDMI audio, i don't know if it works because i have no monitor with speakers to test it.
About the modifications in About This Mac / Pci it are great!!!
Other litle modification in PCI is my soundcard ( Creative Sound Blaster Audigy 4 PRO)
Let me do some questions:
I installed one modified bios from:
https://github.com/danielstuart14/ASUS_BIOS_REPO
You tick - AsusAICPUPM-> so i can untick it from clover right?
And you insert :
DropTables
Signature
DMAR
Signature
SSDT
TableId
CpuPm
Signature
SSDT
TableId
Cpu0Ist
With generated ssdt by script i need it at clover?
What it do?
I like to know about hackintosh!!!
Thanks a lot MaLd0n for help me!!
Cheers
And you insert :
DropTables
Signature
DMAR
Signature
SSDT
TableId
CpuPm
Signature
SSDT
TableId
Cpu0Ist
What it do?
Cheers
AsusAICPUPM, no problem, the option work for all
DROP Tables, ever drop 3 tables ;)
