Broadcom Patcher - Broadcom Wi-Fi Patcher for macOS Tahoe, Sequoia and Sonoma Hackintosh
Broadcom Patcher is a macOS utility designed to simplify the Broadcom Wi-Fi patching process on Hackintosh systems using OpenCore, Clover, or both bootloaders in the same EFI folder.
The app provides a simple drag and drop workflow: just drop your EFI folder, mounted EFI partition, OpenCore folder, Clover folder, or IORegistry dump, and Broadcom Patcher automatically applies the required Wi-Fi patches for supported macOS versions, including macOS Tahoe, macOS Sequoia and macOS Sonoma.
Broadcom Patcher is especially useful for users who need to restore or enable Broadcom Wi-Fi support after Apple removed native support for many legacy Broadcom wireless cards in newer macOS releases.
Download HERE
Anyone who would like to support the project with donations is very welcome and greatly appreciated. Link HERE
Main Features
  • Drag and drop EFI patching
  • Supports OpenCore
  • Supports Clover
  • Supports EFI folders containing OpenCore and Clover together
  • Automatic bootloader detection
  • Automatic Broadcom Wi-Fi detection using IORegistry
  • Supports IORegistry dump files for patching EFI folders from another computer
  • Automatically copies the required Broadcom kexts
  • Replaces outdated Broadcom kexts with the correct included versions
  • Applies OpenCore Kernel/Add, Kernel/Block, NVRAM, Misc/Security, and DeviceProperties
  • Applies Clover KernelAndKextPatches/KextsToBlock, RtVariables, Boot/Arguments, and Devices/Properties
  • Automatically applies the correct SIP configuration
  • Automatically applies Tahoe-specific boot arguments only when needed
  • Supports Intel and AMD Hackintosh systems
  • Automatically disables AirportBrcmFixup.kext on AMD systems
  • Creates automatic config.plist backups before patching
  • Shows a final OpenCore Legacy Patcher download prompt after patching
  • Uses OCLP-Plus link for macOS Tahoe
  • Uses Dortania OpenCore Legacy Patcher link for Sonoma, and Sequoia
OpenCore Support
For OpenCore EFI folders, Broadcom Patcher automatically updates:
  • EFI/OC/Kexts
  • Kernel -> Add
  • Kernel -> Block
  • NVRAM
  • Misc -> Security
  • DeviceProperties -> Add
The app keeps the correct Broadcom kext order and avoids duplicate entries in config.plist.
Clover Support
For Clover EFI folders, Broadcom Patcher automatically updates:
  • EFI/CLOVER/kexts/Other
  • KernelAndKextPatches -> KextsToBlock
  • RtVariables -> CsrActiveConfig
  • Boot -> Arguments
  • Devices -> Properties
Clover support is useful for users who still maintain legacy Clover EFI folders or dual-bootloader setups.
OpenCore + Clover in the Same EFI
Broadcom Patcher supports EFI folders using both bootloaders together, such as BootLoaderSelector setups:
EFI/
├── BOOT/
├── OC/
│   └── config.plist
└── CLOVER/
    └── config.plist
If both bootloaders are detected, the app patches both OpenCore and Clover in the same process.
macOS Tahoe Support
For macOS Tahoe, Broadcom Patcher automatically applies the extra boot arguments required for Broadcom Wi-Fi patching:
-amfipassbeta amfi=0x80 ipc_control_port_options=0
These Tahoe-specific boot arguments are not applied to Sonoma, or Sequoia.
After patching, the app shows the correct OCLP download link:
  • macOS Tahoe: OCLP-Plus
  • macOS Sonoma, Sequoia: Dortania OpenCore Legacy Patcher
Broadcom DeviceProperties Detection
Broadcom Patcher can scan the current IORegistry or an IORegistry dump from another Hackintosh to detect the Broadcom Wi-Fi device path dynamically.
When a valid Broadcom Wi-Fi device is detected, the app applies the required properties automatically:
  • OpenCore: DeviceProperties -> Add
  • Clover: Devices -> Properties
If no Broadcom Wi-Fi device is detected, the app does not create fake or generic PCI paths. This keeps the EFI safer and avoids incorrect device injection.
AMD Hackintosh Support
On AMD Hackintosh systems, Broadcom Patcher automatically handles AirportBrcmFixup.kext differently:
  • OpenCore: keeps the entry but disables it
  • Clover: does not copy AirportBrcmFixup.kext
This helps avoid known compatibility issues on AMD platforms.
Safety
Broadcom Patcher works locally on your Mac. It does not collect data, upload files, send telemetry, or modify anything outside the selected EFI folder.
Before changing any config.plist, the app creates a backup so users can restore their previous configuration if needed.
Credits
Created by MaLd0n / Daniel Maldonado / Olarila
Credits and thanks to the developers and projects that made Broadcom Wi-Fi patching possible:
  • OpenCore / Acidanthera
  • AirportBrcmFixup
  • AMFIPass
  • OpenCore Legacy Patcher / Dortania
  • OCLP-Plus / YBronst
  • Apple legacy Broadcom Wi-Fi frameworks and kexts
  • Like 4
  • Thanks 1
