icecold Posted January 20, 2017 Posted January 20, 2017 I created a USB Install from a raw file I found online(created by a moderator of this forum) OS X Yosemite 10.10 (14A389) bootable USB for Intel PCs Type: Applications > Mac Files: 1 Size: 5.13 GiB (5503970159 Bytes) Tag(s): mac os x yosemite 10.10 14A389 hackintosh Uploaded: 2014-10-17 15:48:10 GMT By: Olarila Everything worked fine, the OS X was installed on a fresh HD, then when I reboot, the boot loader progress bar hangs up half way, I tried everything using more parameters for Clover and disabling vt-d on my BIOS, my configuration is as follows: Intel DX58SO Extreme motherboard, i7 950, Sapphire Radeon 6870HD, and I have 8 Gb DDR3 RAM, and writing from an old Mac OS X 10.7.5 Lion, on another disk that works fine and is pretty stable. My Yosemite Installation reveals that Clover has been installed and it appears to be installed properly, my problem is it gets stuck half way on boot ... the verbose part doesn't stop it ends and then the gray screen with progress bar shows up but there's were it ends, I left the computer unattended to see if it will resume but nothing it simply resets after a while.
Administrators MaLd0n Posted January 20, 2017 Administrators Posted January 20, 2017 u try in safe mode? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
icecold Posted January 22, 2017 Author Posted January 22, 2017 Yes I did and tried many parametrs in Clover args ... but believe it or not, I solved it after doing a diskutility repair from the Recovery HD and reinstalling Yosemite from the USB stick. Righ now the system is stable and I did a combo update to 10.10.5. Netflix, YouTube and other streaming services stopped working ... it has to be Yosemite but I have Lion on another disk and in he same rig, and when I boot in it, everything works as expected.
