try with clover patches, remove dsdt and use it
config.plist.zip
It didn't work. I'm going to try this on my own at a later time, just one questions, and by the way thanks for the help. going back to the original questions that I posted, how did you remove those 3 errors, so that I can start from scratch on my own pace.
thanks, after hours of searching, I manage to get the display preference pane to show by following this guide
https://www.tonycrapx86.com/threads/display-preferences-pane-not-loading-in-sierra-solved.202365/
I'm going to check weather or not with this fix I can get sleep to work and I'll report back, and the last thing that I would need to fix would be sound, it's been a long long and I'm super tired, I'll continue this tomorrow or another day. hey again thanks a lot for the help.
