Alex_F3r Posted 6 hours ago Posted 6 hours ago I have a Toshiba Satellite L50-A-1FQ: i7 4700QM 16GB RAM GT 740M (Disabled) BCM4360 Azure WiFi+BT card The sound codec is IDT 92HD99BXX (as said in title) and the only layout is 3 but it doesn't work, Hackintool detects the codec and all but macOS doesn't detect any inputs or outputs, i've tried Big Sur with macbookpro11,3 and Monterey with macbookpro11,4 smbios, no os works for sound. For the screen, it works but upon boot I can't change brightness, and almost every time keyboard and trackpad don't work, even with kb not working, I can use the fn+f2/3 to change brightness and it shows on the screen the brightness popup, only when I close the lid, wait for it to try and sleep and open it back up, the brightness works and same for kb and trackpad. Tell what I need to attach, im new to here. link to screenshots: https://imgur.com/a/agBHfKJ
