[SOLVED] Audio on P5P43TD-PRO
After months of reading threads, finally I've found a solution to use AppleHDA on ALC887!!!
First, you have to modify your DSDT in this way:
- into the Method (_L0D, 0, NotSerialized), add the following:
Notify (\_SB.PCI0.HDEF, 0x02)
- Add an HDEF Section under the PCI0 device with the following lines:
Device (HDEF)
               Name (_ADR, 0x001B0000)
               OperationRegion (HDCS, PCI_Config, Zero, 0x60)
               Field (HDCS, DWordAcc, NoLock, Preserve)
                   VID0,   16,
                   DID0,   16,
                           Offset (0x4C),
                   DCKA,   1,
                           Offset (0x4D),
                   DCKM,   1,
                       ,   6,
                   DCKS,   1,
                           Offset (0x54),
                       ,   15,
                   PMES,   1
               Method (_PRW, 0, NotSerialized)
                   Return (Package (0x02)
                       0x0D,
                       0x05
                   Store (Package (0x0E)
                           "subsystem-id",
                           Buffer (0x04)
                               0xA0, 0x00, 0x00, 0x00
                           "subsystem-vendor-id",
                           Buffer (0x04)
                               0x86, 0x80, 0x00, 0x00
                           "codec-id",
                           Buffer (0x04)
                               0x85, 0x08, 0xEC, 0x10
                           "layout-id",
                           Buffer (0x04)
                               0x77, 0x03, 0x00, 0x00
                           "platformFamily",
                           Buffer (One)
                               0x00
                           "MaximumBootBeepVolume",
                           Buffer (One)
                               0x40
                           "PinConfigurations",
                           Buffer (One)
                               0x00
                       }, Local0)
                   Return (Local0)
- copy modified DSDT on root and inside E/E
Then do the rest:
- install LegacyHDA_ALC887.kext in E/E
- install AppleHDA.kext 1.7.9 in S/L/E
- repair permissions in E/E and S/L/E
- reboot
- once rebooted, verify in System Profiler/Audio if all is recognized correctly, and choose in System Preferences/Sound "line-out" for the output.
For the attachments exceed 1MB limit, you can download them from this post: http://bit.ly/mXw5zx
