Greetings Maldon! I've been attempting to install Monterey using your appropriate EFI however halfway through the process, I get this error----> An Error Occurred Loading The Update. I've tried another Install SSD, as well as an attempt at Sonoma with the exact same results. The System Clock (bios) was not displaying correctly so I adjusted that. Weird thing is the time is not updating itself after I reboot and go into the bios. Not sure if that's playing a part in this issue. Thanks very much!
Gigabyte Z179XP-SLI
iNtel i7-6700K
Try with recovery mode
https://www.mediafire.com/file_premium/2ulsch8fbje1qpg/Recovery_Ventura.zip/file
***With this method you need an internet connection***
1) Format an USB Flash Drive as FAT32.
2) Put com.apple.recovery.boot Folder on root of the USB.
3) Put your EFI Folder on root of the USB.
