Mr Gecko Posted February 24 Posted February 24 Hi, I want to install macOS Big Sur (Hackintosh) on my Lenovo ThinkCentre M910s and need some help. Specs: - Lenovo ThinkCentre M910s Intel Core i3-6100 (Skylake) Intel HD 530 (iGPU) SSD ADATA 256GB HDD 500GB USB WiFi dongle (Vention, Realtek 8821 series + Bluetooth) Notes: I use DisplayPort (DP), not VGA I saw some GitHub builds that boot/install, but some people said DP does not work I’m using a Big Sur raw offline installer image (USB) Planning to use OpenCore I can use LAN first, WiFi is not priority I need help with: BIOS settings minimum kexts SMBIOS recommendation HD 530 / framebuffer settings for DP output common DP fix (if any) for M910s thanks
Administrators MaLd0n Posted February 24 Administrators Posted February 24 Vntura+ need to use KabyLake properties https://github.com/acidanthera/WhateverGreen/blob/master/Manual/FAQ.IntelHD.en.md#intel-uhd-graphics-610-650-kaby-lake-and-amber-lake-y-processors -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
