Hackintosh macOS guide with installation steps, compatibility notes, common problems, and proven fixes for stable systems.
macOS Ventura+ introduces new security and driver changes.
Not all Hackintosh systems are compatible.
Intel 6th–14th Gen CPUs perform best.
AMD GPUs remain the safest option.
OpenCore must be updated before installation.
Older EFI folders may fail to boot.
Wi-Fi support depends on hardware choice.
Some Broadcom cards require additional patches.
GPU acceleration may fail without updates.
Sonoma+ increases requirements for SecureBoot.
SMBIOS selection becomes more important.
USB mapping prevents random disconnections.
Sleep and wake issues are common initially.
Updating kexts resolves most problems.
Fresh installs are more stable than upgrades.
Always backup your system first.
Not all third-party apps are compatible.
Performance is excellent on supported hardware.
Sonoma+ works well when configured properly.
Careful planning ensures a smooth experience.
