I have a msi gt60 barebones (Haswell) and i need some DSDT help. I have everything working except brightness control and hdmi output. I tried using MaciASL to edit my DSDT but was unsuccessful due to errors. Also I'm having troubles with laptop going to sleep and not staying asleep or not waking up. Please if you could help me. Im on Yosemite 10.5.
SPECS:
-CPU: mobile i7 4900mq
-GPU1: HD 4600
-GPU2: Nvidia 970m
-Ram: 16gb 1600
-HDD: SSD
-Chipset: HM87
where is ur ssdt tables .. the graphics are all in ssdt .. hdmi audio and brightness
there it is .. test and report
MSI.zip
first insert this in efi/clover/acpi/patched
then
https://clover-wiki.zetam.org/Configuration/ACPI#acpi_ssdt_ssdt-dropoem
don't use any clover dsdt fix
maybe u need this to patch the hdmi audio in the kext
must find the right one
.config_HD4600_4400_4200.plist.zip
Hey, brightness and sleep works great! Still can't get hdmi port to work. It really isn't a big deal. I appreciate you helping me! You saved me a lot of headaches trying to get it to work. Could I send a donation your way for your help?
if u want donate to the forum
I updated my Yosemite to El Capitan 10.11.4 and everything is working except sleeping and brightness. I do have some graphic glitches during boot and my menu bar up top starts to disappear. Could you help me again with my DSDT and SSDT? My graphics card shows up as HD4600 1536mb.
DSDT&SSDT.zip
ur tables are already patched .. i'm sure is not a problem in the tables ..
dsdt and ssdt is the same u use before .. don't depend from the os x version u are running
I had to uncheck load OEM and remove the patched DSDT and SSDT because during the update it kept getting a kernel panic. If you could please take a look at my DDST and SSDT's.
what u say is u disable load oem ?
if u do that u do right..
why u go load oem .. if u already have patched dsdt and ssdt ?
i think u must read + about u are trying to achieve .. hack os x is not easy .. u need to read a ton of info .. google ..
or simple .. u buy a mac and problems solved ..
