How to enable Audio on macOS Tahoe with OpenCore Legacy Patcher
How to enable Audio on macOS Tahoe with OCLP - OpenCore Legacy Patcher
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
-Why Olarila doesn't support TonyMac, Reedit, Little-Translated and others HERE
Apple has removed AppleHDA.kext responsible for analog audio support on macOS Tahoe beta 2.
1. Download OCLP HERE
2. Add AMFIPass.kext in EFI folder. Download HERE
3. Set the csr-active-config to 03080000, disable SecureBootModel in Misc / Security tab and add your alcid=xx in NVRAM tab then reboot and reset NVRAM on boot picker. Check HERE about correct alcid for your audio codec.
4. Run and Install OCLP
5. Run OCLP from Applications folder then go to Post Install Root Patcher then Start Root Patching
6. Reboot the system
We're all here to have fun and learn from each other! That's all Folks!
Credits:
Just follow this tutorial. Work nice. For audio u can use AMFIPass.kext instaed bootarg.
can u just send  a photo that show how to do that in bootarg how can I type the command
how about that efi folder
is that work for me ??
https://www.mediafire.com/folder/0yapdk5jhblvd/EFI
