Moro44 Posted March 1, 2016 Posted March 1, 2016 I do not speak English, there is a problem. Error 4057 Name already exists in scope (LPC0) MaciASL All other errors corrected himself. If anyone can help fix the problem. Comment please on how to do it. Thanks in advance. z68_dsl2.dsl.zip
artur-pt Posted March 1, 2016 Posted March 1, 2016 hello post ur clean dsdt good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
Moro44 Posted March 1, 2016 Author Posted March 1, 2016 hello post ur clean dsdt good hack First DSDT.DSL with a patch for z68xp-UD4 acpi_dsdt.zip GA Z68XP-UD4.zip
artur-pt Posted March 1, 2016 Posted March 1, 2016 hello there it is DSDT.aml.zip good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
Moro44 Posted March 1, 2016 Author Posted March 1, 2016 Sorry, I'm a little confused. This is the first *.dsl or second * .bin?
artur-pt Posted March 1, 2016 Posted March 1, 2016 hello is the clean one .. good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
Moro44 Posted March 2, 2016 Author Posted March 2, 2016 2 artur-pt. Many thanks! Good luck to you all.
