Definitive USB Remap Guide for Hackintosh on all macOS, Tahoe included
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
-Why Olarila doesn't support TonyMac, Reedit/Hackintosh, Little-Translated and others HERE
Connector types in the ACPI specification(pages 524 and 525): HERE 9.13 _UPC (USB Port Capabilities)
-What we need? USB2, USB3 and USB-C devices.
-macOS has a limit of 15 USB ports including HSxx and SSxx ports on XHCI/XHC device.
-If your motherboard has more than 15 USB ports, you will need to sacrifice some ports.
-The XhciPortLimit quirk works up to Sequoia. You can enable this quirk and remap it all at once without having to restart your PC.
-After remap uncheck the XhciPortLimit quirk in the Kernel tab of your config.plist.
-After remap stay with XHCI-unsupported, remove only USBInjectAll and inject new USB kext.
-HSxx ports is USB2 and SSxx ports is USB3. You don't need remap ports like TXHC, remap only XHCI/XHC ports. Check example bellow.
Let's start!
1- Download USBInjectAll and Hackintool bellow.
USBInjectAll 4All.zip Hackintool.zip
2- Inject USBInjectAll and XHCI-unsupported via bootloader then restart.
3- Open Hackintol and go to USB tab.
4- Start connect USB2 device in all ports and you will be able to identify the USB2 ports in the Hackintool in the green ports.
5- The ports that did not turn green are not used and we need to delete them for the USB3 ports to appear
6- For this we will use the bootarg uia_exclude and in that case it will be like this.
Quote
uia_exclude=HS02;HS08;HS09;HS10;HS11;HS12
7- The first step is complete. Restart your PC and let's move on to the second step. After reboot we will see many SSxx ports, which are the USB3 ports. Start connect USB3 device in all ports and you will be able to identify the USB3 ports in the Hackintool in the green ports.
8- Let's add some more ports to the bootarg uia_exclude then reboot again.
Quote
uia_exclude=HS02;HS08;HS09;HS10;HS11;HS12;SS05;SS06;SS07
9- After the reboot we already have the final result and now we will change to the correct USB connector.
10- USB Connectors. Basically we will need Internal, USB3 and USB-C in Haswell+.
Internal - Use to CAM, Bluetooth and USB2 HUB internal.
USB3 - Use in common ports USB-A on HSxx and SSxx ports.
Type-C+SW - Use in USB-C ports.
11- Let's use Hackintool to change the Connectors. It's very easy. Just set correct Connectors then generate USBPorts kext.
Easy Way to stay with correct connectors is save USB kext on Windows with USBToolBox and after that delete the unused ports.
To delete ports open the .plist kext with good plist editor like PlistEditPro, select all unused ports then delete, just follow the remap procedure in this tutorial.
In macOS Tahoe, Apple changed USB properties, and we need two properties specific to this version of the system. You can use your old kext and inject these properties very easily with USBMap by corpnewt.
This procedure work for USBPorts.kext by Hackintool, UTBMap.kext by USBToolBox and old USBMap.kext by USBMap.
 Download USBMap HERE
Run USBMapInjectorEdit.command on macOS or USBMapInjectorEdit.bat on Windows
Drag .plist USB kext into terminal
Then press U and done. Your kext is ready for macOS Tahoe.
We're all here to have fun and learn from each other! That's all Folks!
Credits:
