Help Using System Info
I am a Hackintosh newbee trying to install OS X on a no name netbook.
I have tried several different hackintosh installations but the closest I have gotten is a hung OS X boot up with a squealing noise.
I have downloaded SystemInfo and run it under windows. I get all green checks or happy faces with one exception: Device ID A010, Intel N10 Family Integrated Graphics Controller shows me a frowning face.
To be honest I have no idea where to go from here.
Is it possible to use the information provided by System Info to build a install that will work?
If so can someone point me to a guide that will let me learn enough to actually do it?
Or does the one frowning face tell me I am out of luck?
Any suggestions appreciated!
You probably won't have hardware graphics acceleration, since your card is not supported, but you shouldn't have problem to install the system.
For installation you can use any method, via USB (myHack, OSX86 ModUSB, need access to a Mac to create the bootable USB) or boot CD + DVD if you have an external DVD drive.
