I installed Big Sur to my Aorus Z690 Elite, RTX 3070, GT730, i5-12400F system. the board have an 3 pcie slot. my main card is 3070 for windows gaming and use gt730 on mac perfectly BUT 3070 is getting hot on macos and i tried but wont success disable with ssdt. need help for disable. thanks
use this patch with correct pci adr
Quote
<key>PciRoot(0x0)/Pci(0x6,0x0)/Pci(0x0,0x0)</key>
                <dict>
                    <key>disable-gpu</key>
                    <data>AQAAAA==</data>
                </dict>
