How to enable Audio and USB on macOS Tahoe with OCLP Mod
Easy wayt to enable Audio and USB in macOS Tahoe
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
-Why Olarila doesn't support TonyMac, Reedit, Little-Translated and others HERE
Apple has removed AppleHDA.kext responsible for analog audio support on macOS Tahoe beta 2.
You don't need the USB patcher in general, the USB work normally, just follow tutorial HERE.
If you need to use a USB WIFI this patcher is mandatory, at least for now.
1. Download OCLP MOD HERE Credits to laobamac
2. Download and install KDK HERE
3. Add AMFIPass.kext in EFI folder. Download HERE
4. Set the csr-active-config to 03080000, disable SecureBootModel in Misc / Security tab and add your alcid=xx in NVRAM tab then reboot and reset NVRAM on boot picker. Check HERE about correct alcid for your audio codec.
5. Run and Install OCLP MOD
6. Run OCLP MOD from Applications folder then go to Settings
7. Go to tab in image bellow and select HDA and USB then back. "Deselect all options in all other tabs. We don't need these things on Hackintosh."
8. Go to Patcher
9. Then Run
10. Reboot the system
We're all here to have fun and learn from each other! That's all Folks!
Credits:
