telepati Posted October 22, 2015 Posted October 22, 2015 Hi guys how to fix that error 'object does not exist ( _sb.pci0.peg0.pegp)'. After used PJALM Gigabyte Z87X UD5H patch Im getting this error. I marked with red. Line 12032 object does not exist ( _sb.pci0.peg0.pegp) Method (BRTN, 1, Serialized) { If (LEqual (And (DIDX, 0x0F00), 0x0400)) { Notify (\_SB.PCI0.GFX0.DD1F, Arg0) } } Scope (_GPE) { Method (_L09, 0, NotSerialized) // _Lxx: Level-Triggered GPE { If (LEqual (RP1D, Zero)) { \_SB.PCI0.RP01.HPME () Notify (\_SB.PCI0.RP01, 0x02) } If (LEqual (RP2D, Zero)) { \_SB.PCI0.RP02.HPME () Notify (\_SB.PCI0.RP02, 0x02) } If (LEqual (RP3D, Zero)) { \_SB.PCI0.RP03.HPME () Notify (\_SB.PCI0.RP03, 0x02) } If (LEqual (RP4D, Zero)) { \_SB.PCI0.RP04.HPME () Notify (\_SB.PCI0.RP04, 0x02) } If (LEqual (RP5D, Zero)) { \_SB.PCI0.RP05.HPME () Notify (\_SB.PCI0.RP05, 0x02) } If (LEqual (RP6D, Zero)) { \_SB.PCI0.RP06.HPME () Notify (\_SB.PCI0.RP06, 0x02) } If (LEqual (RP7D, Zero)) { \_SB.PCI0.RP07.HPME () Notify (\_SB.PCI0.RP07, 0x02) } If (LEqual (RP8D, Zero)) { \_SB.PCI0.RP08.HPME () Notify (\_SB.PCI0.RP08, 0x02) } If (LEqual (D1F0, One)) { \_SB.PCI0.PEG0.HPME () Notify (\_SB.PCI0.PEG0, 0x02) Notify (\_SB.PCI0.PEG0.PEGP, 0x02) } If (LEqual (D1F1, One)) { \_SB.PCI0.PEG1.HPME () Notify (\_SB.PCI0.PEG1, 0x02) } If (LEqual (D1F2, One)) { \_SB.PCI0.PEG2.HPME () Notify (\_SB.PCI0.PEG2, 0x02) } }
artur-pt Posted October 24, 2015 Posted October 24, 2015 hello post ur clean dsdt good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
telepati Posted October 24, 2015 Author Posted October 24, 2015 hello post ur clean dsdt good hack Here is my .dsl file. System DSDT.zip
artur-pt Posted October 25, 2015 Posted October 25, 2015 hello there it is with jpalm patch DSDT.aml.zip good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
telepati Posted October 25, 2015 Author Posted October 25, 2015 hello there it is with jpalm patch [attachment=0]DSDT.aml.zip[/attachment] good hack Thank you so much.
