OS X El Capitan 10.11.6 bootable USB for Intel PCs
Hi I'm new in hackintosh
I have a system that I want to install OSX El Capitan
Processor : Intel Core 2 Quad Q6600
Motherboard : Asus IPIBL-LB (Benicia) Bios : 5.43
RAM : 4GB (2x2GB) ddr2 667
GPU : PowerColor HD 6570 2GB
Storage : SSD for MacOS HDD for Windows 7
I followed the instruction but when I try to install El Capitan I only got black screen.
Currently running Snow Leopard 10.6
[ref]kyle10[/ref], use -x for install, the black screen problem is ur GPU
[ref]psycopedro[/ref], tem as imagens atualizadas aqui no fórum
Hi i tried to install El Capitan from this file in my laptop without success.
My laptop is Toshiba L300 29h. It has a T5870 CPU (core duo) and with a graphic GM45 GMA 4500HD.
I can boot to clover but when i select to boot El capitan system i end with a
Error loading kernel cache (0xe)
Boot failed. sleeping for 10seconds before exiting
Nothing more nothing less. I tried add some boot options as i saw in many tutos. Nothing happen always the same error.
I attach some clover logs.
Thanks in advance
preboot.log
DumpLog.txt
[ref]jefcolbi[/ref], forget it, gpu don't work
[ref]jefcolbi[/ref], don't work
forget it
[ref]MaLd0n[/ref], i tried to install in other laptop an Hp core i3 with two GPU, an HP core i5 and another HP core i5. I always core the previous error. can't even open the installer. just clover.
6 hours ago, paulo peixoto said:
quando chega na hora de formatar, pede conta icloud, eu boto, mas msm assim nao vai, da erro .
não é comum
