lucasogodoy Posted June 13, 2025 Posted June 13, 2025 Hi everyone! I’m using a Lenovo S145-15IIL-82DJ000GBR with an Intel Core i5-1035G1 and successfully installed Sequoia. I managed to get Wi-Fi working using a BCM94352Z (with OpenCore, the correct kexts, etc.), but I just can’t get Bluetooth to work. I’ve tried several tutorials, added and removed kexts, changed boot-args, and tested different settings, but no luck. Bluetooth works fine on Windows, so I know the card itself isn’t the issue. Does anyone know what might be missing or what I’m doing wrong? Also, one more question: when the laptop goes to sleep and then hibernates, it crashes and won’t wake up. Is hibernation unsupported? If so, what’s the proper way to disable it on Sequoia? Thanks in advance for any help!
Administrators MaLd0n Posted June 13, 2025 Administrators Posted June 13, 2025 This bluetooth need these kexts BlueToolFixup.kext BrcmFirmwareData.kext BrcmPatchRAM3.kext -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
lucasogodoy Posted June 13, 2025 Author Posted June 13, 2025 (edited) I already have those kexts installed. Here’s the list of my current kexts in the order they’re loaded: Lilu.kext VirtualSMC.kext WhateverGreen.kext AppleALC.kext IOSkywalkFamily.kext IO80211FamilyLegacy.kext IO80211FamilyLegacy.kext/Contents/PlugIns/AirPortBrcmNIC.kext BlueToolFixup.kext BrcmFirmwareData.kext BrcmPatchRAM3.kext AirportBrcmFixup.kext AirportBrcmFixup.kext/Contents/PlugIns/AirPortBrcmNIC_Injector.kext CpuTscSync.kext BrightnessKeys.kext ECEnabler.kext FeatureUnlock.kext NullEthernet.kext NVMeFix.kext RestrictEvents.kext SMCBatteryManager.kext SMCLightSensor.kext SMCProcessor.kext SMCSuperIO.kext VerbStub.kext VoodooI2C.kext/Contents/PlugIns/VoodooGPIO.kext VoodooI2C.kext/Contents/PlugIns/VoodooI2CServices.kext VoodooI2C.kext/Contents/PlugIns/VoodooInput.kext VoodooI2C.kext VoodooI2CELAN.kext VoodooI2CSynaptics.kext VoodooPS2Controller.kext VoodooPS2Controller.kext/Contents/PlugIns/VoodooPS2Keyboard.kext USBPorts.kext And here’s my current boot-args: alcid=20 -v i2c-force-polling watchdog=0 agdpmod=vit9696 -noDC9 TSC_sync_margin=0 brcmfx-alldrv brcmfx-driver=2 debug=0x100 keepsyms=1 amfi=0x80 I also blocked IOSkywalkFamily in the Kernel section and added the bluetoothExternalDongleFailed and bluetoothInternalControllerInfo variables to the Delete section of NVRAM: Edited June 13, 2025 by lucasogodoy
